  • Crypts
    • Feb 2023
    • 20
    • Algeria
    #3061
    Hello have you try this file me be it helps ...
    https://www.badcaps.net/forum/troubl...72#post1606172
    I tried this dump but no screen!!
    • Obaid ur Rehman
      • Dec 2023
      • Pakistan
      #3062
      I successfully removed BIOS password from Lenovo thinkpad t480.
      But now I'm unable to boot Windows from USB drive.
      Is there any issue from BIOS side..?
      • pdblues2231
        • Jun 2022
        • 53
        hi, there
        the auto patcher will not currently work with a t490 or above because of the mec chip, other solutions exist and must be used.
        • Obaid ur Rehman
          • Dec 2023
          • Pakistan
          #3064
          I'm just wondering
          ​​​​​​Is this method of removing Supervisor Password create any Issue in Booting Process (from a USB) ..?
          • Obaid ur Rehman
            • Dec 2023
            • Pakistan
            #3065
            I'm just wondering
              Vesko356 commented
              Editing a comment
              No, it doesn't create such problems.
          • Steve Budarz
            • Jan 2024
            • US
            #3066
            Originally posted by pdblues2231
            hi, there
            When I saw "up to 8th gen" I thought that meant the 8th gen intels. It looks like the flashers for the T490 solution are a bit more expensive. Do the mobos on the T490 with the 8th gen processor use the chips I can flash with this tool, or do I need to go find the T490 method?
            • abdulhalim933
              • Oct 2015
              • 14
              • damascus
              #3067
              great
              where is the files to download?
            • Obaid ur Rehman
              • Dec 2023
              • Pakistan
              #3068
              Anyone tried this method of BIOS Password Removal on Lenovo thinkpad t580..?
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria πŸ‡§πŸ‡¬
                #3069
                You MUST:
                • Use search function in case someone already answered your request
                Use the search engine before asking questions please!
                Some search results within this thread especially for you:
                https://www.badcaps.net/forum/troubl...08#post1556208
                https://www.badcaps.net/forum/troubl...72#post1781772
                https://www.badcaps.net/forum/troubl...23#post1795023
                https://www.badcaps.net/forum/troubl...52#post1809652
                Become a Badcaps supporter
                Thanks to all supporters.​
                • chanavs
                  • May 2015
                  • 6
                  • india
                  #3070
                  Hi
                  Tried on t480. Files patched but no display any solution.
                  • abdulhalim933
                    • Oct 2015
                    • 14
                    • damascus
                    #3071
                    Originally posted by chanavs
                    Hi
                    i've tried yesterday on t480 and worked fine
                    Some models have a back cover sensor "switch" and gives you a beeps with no display after flashing
                    You should to put the back cover to get a display
                    • Hydrolics123
                      • Jan 2024
                      #3072
                      OMG! @Knucklegrumble thank you so much for your help!
                      Because of you, I was able to remove the BIOS password on my Lenovo T440P.
                      I followed your instructions and it worked perfectly.
                      I used the common CH341A MiniProgrammer with the clamp tool and it worked a treat!
                      I did have one little issue that I'll like to make others aware if they come across this issue:
                      • After I received the PATCHED file (using the AutoPatcher file @Knucklegrumble provided) I erased the original data on the BIOS chip and programmed it with the 'PATCHED' BIN file.
                      • After it was programmed I turned the laptop on and followed (Step 3-6) which worked flawlessly.
                      • However when I went back to programing the original BIN file I had saved, it wasn't verifying - giving errors
                      • Failing that, I still went to see if the laptop would turn on - it wasn't was beeping 5 times pause and then beeped 5 times again.
                      • I then went back onto connecting the programmer onto the chip and erased all the data it had.
                      • I then verified the erased data - passed
                      • I then opened the original BIN folder I had saved and programed it again
                      • The data was programmed
                      • I then did another verification test, and thankfully! It passed with no faults this time.
                      • Booted the laptop again and BOOM! it was back to being alive with no more BIOS password.
                      Really hope this can help anyone if they ever come across what I had.
                      Again, I can't thank the community enough for this.
                      I'll be sure to help out others if they experience issues while undertaking this job.
                      Many thanks,
                      Haidhur
                      • Hydrolics123
                        • Jan 2024
                        #3073
                        Hi
                        Hi mate, have you tried verifying the BIN data that you have on the Chip?
                        Make sure it gives no errors
                        Be sure to let me know
                        • Pep2923
                          • Jan 2024
                          I patched 2 T440 and it worked flawlessly. I can confirm, it does work on Fedora 39 with Python 3.12.1 with ch341a_spi.
                          Make sure you do 'chmod 777 tools/UEFIReplace' as root, otherwise you get an error from Python.
                          The 2*5 beep and checksum error upon boot you eliminate by setting the BIOS to the defaults. For that i had to press F1 to get instantly to the settings, even though this option is not to be seen on the Lenovo POST. At least in my case. I even had to reboot a few times, because it froze. If you are asked to type in a SVP (supervisor password), really type something random in and press ENTER. I did not work for me to leave it blank. After that you are asked to press SPACE two times and turn it off.
                          Also, don't forget to remove the HDD during the whole procedure. I also disconnected the CMOS battery.
                          I put the autopatcher in the attachments for those where the file does not appear in the first post.
                          • EffiSon
                            • May 2020
                            • 38
                            • Sweden
                            #3075
                            Thank you very much for the autopatcher attachment.
                            Yes for some reason the autopatcher is not visible on the first post
                            • melchor0815
                              Hi guys,
                              IΒ΄ve an T480 and forgotten the SVP. I bought a CH341A programmer and was able to read the BIOS chip. (see attached file).
                              At the point with python I struggled a bit and so IΒ΄m not sure, If the patched file is correct.
                              Could someone take a look at it and could give me a helping hand?
                              Original dump and patched dump is attached.
                              Type: 20L5-0063GE
                              S/N: PF-1HZRLK 18/12
                              Bios Winbond 25Q128JV
                              Bord # ET480 NM-B501 Rev 1.0 2018-03-05​
                              Thanks a lot
                              • cristiannec
                                • Oct 2014
                                • 51
                                • Italia
                                #3077
                                Originally posted by melchor0815
                                Hi guys,
                                Type: 20L5-0063GE
                                Thanks a lot
                                Try
                                • kordex35
                                  • Apr 2015
                                  • 49
                                  • Polska
                                  #3078
                                  Ok
                                  • melchor0815
                                    Big THANKS to you.
                                    You made my day kordex35 and cristiannec
                                    Everything worked and now I can change my settings. Great job.
                                    πŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒπŸ˜ƒ
                                    • apachioara
                                      • May 2022
                                      #3080
                                      Worked flawlessly on T640p, MB: BT463 NS-A611, rev. 1.0, BIOS IC: MXIC MX25L12873F with CH341A and Siberia programming software.
                                      Thanks a lot!
                                      • macabook
                                        πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        11-14-2025, 04:04 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • istvanszasz99
                                        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                        by istvanszasz99
                                        Product ID: RZ09-0421
                                        Motherboard: CH580
                                        Bios File Size: 32,768 KB
                                        Dear Forum Readers!
                                        !!! MY RAZER BLADE...
                                        11-24-2025, 05:52 PM
