BIOS REQUEST HP 430 g3
Re: BIOS REQUEST HP 430 g3
Here, read post #184 https://www.badcaps.net/forum/showth...=79956&page=10 .If you can`t read it using the clip then you`ll have to desolder the bios.
With some programmers you need to do this:
*Remove battery
*Attach charger
*Turn on laptop and go to F1, F10 or wherever you like
*Turn off laptop holding down power button (DO NOT REMOVE CHARGER)
*Attach programmer
*Read bios chip content
*Use verify function or read content one more time and compare using hex editor software
*If all is okay, use HPUnlocker tool on the VERIFIED bios dump
*Write the xxx_unlocked.bin file
*Verify bios content
You must always make sure you verify everything you read/write, I cant stress this enough.
And those few first steps are mandatory with some programmers unless you unsolder the chip.Last edited by SMDFlea; 07-17-2020, 11:58 AM.Comment
What are you attaching your programmer to ? ,maybe it isn`t proving enough amperageComment
Well im using one of these with the bios chip soldered to it.
Attaching it to my ACER laptop.
Maybe its the installation thats the issue.?
I assume my laptop will provide enough voltage?Attached Filesif you find these attachements useful please consider making a small donation to the site
This is exctly what I am doing although with a different programmer.Comment
guys this one may be correct..
pls check..thnxAttached Filesif you find these attachements useful please consider making a small donation to the site
Your bios backup is corrupt near the end. Make another backup to make sure,and post it.Comment
The backup appears to be good although the bios itself is corrupt. I can`t find a password in it,i could be wrong.Comment
There def is an admin password on the machine.
hpunlocker tool has generated a new file for this bin,shall I write the chip with that and test.?Comment
Yes go for it.Comment
That BIOS definitely looks corrupt. If the laptop is working, there's an issue when dumping the BIOS and I'd definitely not feel safe flashing the BIOS.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
