BIOS REQUEST HP 430 g3
  • vikivng
    • Feb 2019
    • 228
    Re: BIOS REQUEST HP 430 g3
    Originally posted by lapfix
    empty one , you waste your time .
    your bios is near bios battery ...the only one .
    https://ae01.alicdn.com/kf/HTB1_D3nb...3-I7-6500U.jpg
    this is chip im using. circled in yellow. isnt this the correct one??
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      yes
        • 22096
        Here, read post #184 https://www.badcaps.net/forum/showth...=79956&page=10 .If you can`t read it using the clip then you`ll have to desolder the bios.
        With some programmers you need to do this:
        *Remove battery
        *Attach charger
        *Turn on laptop and go to F1, F10 or wherever you like
        *Turn off laptop holding down power button (DO NOT REMOVE CHARGER)
        *Attach programmer
        *Read bios chip content
        *Use verify function or read content one more time and compare using hex editor software
        *If all is okay, use HPUnlocker tool on the VERIFIED bios dump
        *Write the xxx_unlocked.bin file
        *Verify bios content
        You must always make sure you verify everything you read/write, I cant stress this enough.
        And those few first steps are mandatory with some programmers unless you unsolder the chip.
        • vikivng
          • Feb 2019
          • 228
          Ok,
          so the process is
          1 desolder the chip and solder to the programmer
          2 connect to software via usb and read the chip.?
          I dont understand what im doing wrong.
          Maybe the drivers.? I did install them.
          • vikivng
            • Feb 2019
            • 228
            Thnx but I have desoldered the chip and soldered directly to the programmer as advised earlier in the thread.
            What could be the cause of the empty reads.?
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #26
              Originally posted by vikivng
              Ok,
              so the process is
              https://www.youtube.com/watch?v=m4nkonNmAmA
                • 22096
                What are you attaching your programmer to ? ,maybe it isn`t proving enough amperage
                • vikivng
                  • Feb 2019
                  • 228
                  #28
                  Well im using one of these with the bios chip soldered to it.
                  Attaching it to my ACER laptop.
                  Maybe its the installation thats the issue.?
                  I assume my laptop will provide enough voltage?
                  • vikivng
                    • Feb 2019
                    • 228
                    #29
                    This is exctly what I am doing although with a different programmer.
                    • vikivng
                      • Feb 2019
                      • 228
                      #30
                      guys this one may be correct..
                      pls check..thnx
                      • vikivng
                        • Feb 2019
                        • 228
                        #31
                        I think I was using the wrong version for the black pcb programmer and also the driver with windows 10 had issues.
                        hope you guys still up..really want this to work..
                        • vikivng
                          • Feb 2019
                          • 228
                          #32
                          Anyone around?
                            • 22096
                            Your bios backup is corrupt near the end. Make another backup to make sure,and post it.
                            • vikivng
                              • Feb 2019
                              • 228
                              #34
                              Here is the new read. Is it the same.? size seems different.
                              • vikivng
                                • Feb 2019
                                • 228
                                #35
                                Hi guys..is this correct flea?
                                  • 22096
                                  The backup appears to be good although the bios itself is corrupt. I can`t find a password in it,i could be wrong.
                                  • vikivng
                                    • Feb 2019
                                    • 228
                                    #37
                                    There def is an admin password on the machine.
                                    hpunlocker tool has generated a new file for this bin,shall I write the chip with that and test.?
                                      • 22096
                                      Yes go for it.
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        #39
                                        That BIOS definitely looks corrupt. If the laptop is working, there's an issue when dumping the BIOS and I'd definitely not feel safe flashing the BIOS.
                                        • vikivng
                                          • Feb 2019
                                          • 228
                                          #40
                                          Whats the worst case scenario.?
                                          What would make the bios corrupt in the case of the attempted dump?
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
