dell precision m3800 with a locked bios
post the original content of the bios chipDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Here the Bios fileAttached FilesComment
I have unlocked the laptop using this method:
https://www.badcaps.net/forum/troubl...4-asus-tp412fa
This was my password:KKG6742DCComment
​https://www.badcaps.net/donateComment
Greetings! I have a locked M3800, the issue is, I don't have a programmer to get a BIOS dump, but judging by some replies here, help was possible without a dump. I would be eternally grateful if you could help! Service Tag: 73K5VZ1
Express service code: 15452741917
I have a Dell M3800 laptop with BIOS Admin password.
Service Tag CD0YX52
Express service code: 26909077574
Can I ask someone send me a password to unlock it ?
Thank You and much appreciate it.
Hello, ok I will try to do it once I get home from work.
Can You tell me how to save BIOS to file, I mean is there any program or something to do do it ?
I tried to download my BIOS version A09(currently installed) from dell website for my service tag, but it's impossible - oldest available is A10
With that admin password BIOS is practically impossible to modify any setting, even boot menu doesn't work.
Thank You for your answer.Comment
The bios chip must be unsoldered from the board before writing or reading..Hello, ok I will try to do it once I get home from work.
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello again,
I managed to download bios with backup tool (Universal BIOS Backup toolkit 2.0).
File is attached in zip.
Thank YouAttached FilesComment
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by MMH3Hello,
i would appreciate, if someone could help me.
DELL: 3450 sff
Servicetag: (!) obviously FAKE - ABC2345
Mainboard: 0GK35Y - serial /ABC2345/CNFCW0023800L6/
Chipset: Intel W580 (Rocket Lake PCH-H)
BIOS: 1.34.1
ME: 15.0.50.2633
mor data can be found the HW-Info-data in the rar-file
I have this BIOS from a DELL Precision 3450 SmallFormFactor mainboard i bought refurbished.. from china.
The board itself works without any issues.
My goal was to clean the ME of this and fully...-
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
Channel: BIOS Requests ONLY!
by cozilyI bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...-
- Loading...
