Ineed bios for Inspiron 5567 -La-D801P
  • halinka1125
    • Dec 2020
    • 8
    • Poland
    Re: Ineed bios for Inspiron 5567 -La-D801P
    hoaca388 - Your file is better, battery code says 2 amber 7 white - LCD bad. I Connected HDMI - image was shown, but after strictly 38s power off (each time if I turn it on it is 38s), in bios error log shows unknown code 0x0000002f.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12406
      Maybe you should keep testing the hardware.
      • halinka1125
        • Dec 2020
        • 8
        • Poland
        Hmm - maybe, it's strange that it's always 38 seconds - in the bios, when windows starts - always exactly 38 seconds(hot/cold doesn`t matter). Thermal shutdown not registered. Only events from LCD failure, and Unidentified System i about menu. I'll try to find out what's wrong.
        THANK YOU VERY MUCH
        • halinka1125
          • Dec 2020
          • 8
          • Poland
          OK. Some problems fixed
          Bios from post not working, but i found one working <Clear me LA-D801P.bin>. Bios file from hoaca388 gave me a clue that not all in HW is ok. In test Bios chip after few flashes died <echanged from another mobo, new one from aliexpress gave me 3 orange and 5 white blinks but was programming itself good>. LCD Cable was OK, but fuse on LCD matrix was blown <on 3.3V line>, replaceing it <with same amperage rate fuse> was a bad idea:/ I got magic smoke from SY6288C20AAC - lerning from lesson - first short circuit test - then live test:P. On LCD matrix is U1 broken. So LCD is a trash, but all other things working now (there is no shutdown after 38s) . Thank You for help
          PS. How to change ServiceTag in this platform?
          • feqke0wq3
            • Jan 2023
            Hello halinka1125, i have the same trouble with the LCD and the shutdown after 38 Sec. and the Log 0x0000002f.
            Which fuse was defective in your case?
            Can you give me a picture or the number of the fuse?
            Thx
            • halinka1125
              • Dec 2020
              • 8
              • Poland
              #26
              SMD Fuse (size 805) on LCD panel matrix electric board near connector, it is labeled F1 3.3V 1.5A 32V. But 38s shutdown means you have also bad bios...
              Do check on external regulated power supply if Your fuse was blowed. On this matrix 19V and 3.3V pins are very close. I have replaced LCD cable for be 100% sure. Blowed fuse and damaged bios chip and U1 must died for some reason...
              Good luck!
              • ldinfortec
                • Jun 2021
                • brasil
                #27
                Originally posted by hoaca388
                Here
                worked fine for me here. calling in 5 seconds
                • halinka1125
                  • Dec 2020
                  • 8
                  • Poland
                  #28
                  If anyone need zipped Clear me LA-D801P.bin . After replace LCD and flex my dell is 100% working.
                  • Chieftain
                    • May 2016
                    • 72
                    • Greece
                    #29
                    Clear me LA-D801P.zip works fine for my Bios locked dell...
                    Thank you v much
                    • mmaewbsoft
                      • Apr 2018
                      • 66
                      • yemen
                      #30
                      Help me I need bios for Inspiron 5567 BAL20 -La-D801P rev: 1.0 (A00) 2019-09-30
                      CPU SR2ZU Intel i7-7500U
                      GPU AMD 216-0889018​
                      Service Tag: 5X81L22
                      Express Service Code: 12892806362
                      i try many files bois no display fan speed
                      my bacup
                      • TuanTongbadcaps
                        • Mar 2023
                        • 64
                        • VietNam
                        #31
                        my bacup
                        You can try this. I have 2 files here, one is edited from your bios, one has been tested on other machines.
                        • mmaewbsoft
                          • Apr 2018
                          • 66
                          • yemen
                          #32
                          i flash 2 files not working fan speed where is peste and SMDFlea
                          • mmaewbsoft
                            • Apr 2018
                            • 66
                            • yemen
                            #33
                            clean me plz
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12406
                              #34
                              clean me plz
                              Inspiron 15 5567
                              • mmaewbsoft
                                • Apr 2018
                                • 66
                                • yemen
                                #35
                                How can i thank you mr hoaca388 thank very very very much i love you i try flash 28 bin file bois your file clean me working 100%
                                Thank very very much badcaps.net team
                                • mahlcom
                                  • May 2020
                                  • 12
                                  • algerie
                                  #36
                                  Service Tag; 6WCHRF2
                                  MERCI D'AVANCE
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12406
                                    #37
                                    MERCI D'AVANCE
                                    Inspiron 15 5567
                                    Service Tag: 6WCHRF2
                                      DELL Inspiron 5567 Notebook 5000 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 5567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5567 boardview and 5567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5567...
                                      09-06-2024, 08:01 AM
