dell chromebook 11 3189 block Enterprise Enrollement user
  • erikulla
    • Jul 2019
    • 12
    • Vlore
    Hello...i need bin file for dell chromebook 11 3189...motherboard number cav01/11 la-e372p rev 2.0..plss help 🙏🙏🙏
  • peste
    • 13176
    • ROMANIA
    Re: dell chromebook 11 3189 block Enterprise Enrollement user
    try this..
    https://forum.laboneinside.com/viewt...hp?f=41&t=7886
    • erikulla
      • Jul 2019
      • 12
      • Vlore
      This is not the original and does not support chromeOS...
      I tried it and it doesn't work
        • 21439
        Try this bios.
        • erikulla
          • Jul 2019
          • 12
          • Vlore
          I tried it and it doesn't work.. not turning on
          • osman68i
            • May 2015
            • 340
            • The Netherlands
            first start
            esc refresh
            ctrl-d
            space
            try
            • volinakis
              • Jan 2021
              • 2794
              • N/A
              Originally posted by osman68i
              first start
              esc refresh
              ctrl-d
              space
              try
              Hi, I have an Dell 3189 and I did in BIOS same modification you did in previous original file and it worked. Chipset is W25Q64FW (1,8V), not FV as user erikulla wrote
              Big thanks!
              • Johnson
                • Jun 2017
                • 9
                • Nigeria
                Please i need bios for cav01/11 la-e372p rev:1.0(a00)
                • Garikst
                  • Feb 2023
                  • Україна
                  Будь ласка, мені потрібний bios для cav01/11 la-e372p rev:1.0(a00)
                  • Garikst
                    • Feb 2023
                    • Україна
                    Я встановив linux,а потім хотів повернути chromeOs. І щось пішло не так.мені потрібен bin для 25q40 (я його стер CH341a, переплутав мікросхеми ).і тепер він не запускається.
                    Будьласка.#
                    I installed linux and then wanted chromeOs back. And something went wrong. I need a bin for 25q40 (I erased it CH341a, mixed up the chips). and now it does not start.
                    Please.#
                    • ras kenny
                      • Apr 2023
                      • 7
                      • Ghana
                      good evening please is there any dump for cav01/11 la-e372p rev:1.0(a00)
                      • peste
                        • 13176
                        • ROMANIA
                        post here the original bios of the laptop even if it is corrupted..
                        • ssrkh
                          • Jul 2023
                          • 12
                          • Malaysia
                          Thanks me later and donate something to site
                          • tfatt
                            • Sep 2021
                            • 18
                            • Singapore
                            I have this model, dell Chromebook 11 3189. Motherboard version is cav01/11 la-e372p rev:1.0(a00)
                            The bios chipset is W25Q64FW (1,8V). I got the Dell Chrome 3180-3189-Unenrollment.bin from another forum. I applied it to my bios but was unable to boot up with a black screen. I need help on this as I got multiple units of this model. Attached is my dump file. May I know what is wrong with the Dell Chrome 3180-3189-Unenrollment.bin?
                            Thanks to anyone who can help.
                            • volinakis
                              • Jan 2021
                              • 2794
                              • N/A
                              What is wrong is that is from ANOTHER laptop, each bios is UNIQUE for every laptop.
                              After writing new bios reinstall using USB stick made for your model with Chromebook Recovery Utility.
                              • tfatt
                                • Sep 2021
                                • 18
                                • Singapore
                                Hi volinakis,
                                It is wotking and can you guide me on what to edit on the dump file (If i get other units dump files) as I still got other units to remove the enterprise enrolment?
                                Thanks.
                                • volinakis
                                  • Jan 2021
                                  • 2794
                                  • N/A
                                  Hi volinakis,
                                  Thanks.
                                  compare original file against modified one and you'll figure out ...
                                  • tfatt
                                    • Sep 2021
                                    • 18
                                    • Singapore
                                    Okay... thanks for your update
                                    • tfatt
                                      • Sep 2021
                                      • 18
                                      • Singapore
                                      Another question to anyone can help. Earlier I tried on RCUnlocker_v_1_0.
                                      1. Drag the dump bin file to RCUnlocker.
                                      2. It will auto generate a unlock bin file. I flashed that bin file to W25Q64FW chipset but the device is unbootable.
                                      May I know RCUnlocker still workable to unlock developer mode?
                                      • volinakis
                                        • Jan 2021
                                        • 2794
                                        • N/A
                                        No, it will do just half of job.
                                          Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) Spin 513 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Acer Chromebook Enterprise Spin 513 R841T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Enterprise Spin 513 R841T boardview and Acer Chromebook Enterprise Spin 513 R841T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-07-2024, 01:30 AM
                                          Acer Chromebook Enterprise 314 C933T-C5HP Chromebook Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Enterprise 314 C933T-C5HP Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise 314 C933T-C5HP boardview and Enterprise 314 C933T-C5HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 02:00 AM
                                          Acer Chromebook Enterprise 314 C933LT-P0AB Chromebook 314 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Enterprise 314 C933LT-P0AB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise 314 C933LT-P0AB boardview and Enterprise 314 C933LT-P0AB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 12:10 AM
                                          Acer Chromebook Enterprise Spin 513 R841T-S7SQ Chromebook Spin 513 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Enterprise Spin 513 R841T-S7SQ Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise Spin 513 R841T-S7SQ boardview and Enterprise Spin 513 R841T-S7SQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 11:40 PM
                                          Acer Chromebook Enterprise Spin 514 CP514-1W-R9VE Chromebook Spin 514 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Enterprise Spin 514 CP514-1W-R9VE Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise Spin 514 CP514-1W-R9VE boardview and Enterprise Spin 514 CP514-1W-R9VE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-06-2024, 11:20 PM
