lenovo IdeaPad S145 bios needed
  • Dominiks1980
    • Nov 2023
    • 14
    • Polska
    #401
    The bios you gave is your bios with my DMI?
      • 22035
      Its the latest version extracted from lenovo support + your DMI .
      • Dominiks1980
        • Nov 2023
        • 14
        • Polska
        #403
        Thank you, I'm going to exchange it.
        • Dominiks1980
          • Nov 2023
          • 14
          • Polska
          #404
          Still no DMI
          • Dominiks1980
            • Nov 2023
            • 14
            • Polska
            #405
            I wanted to try to enter the serial number using AMIDEDOS, but the pendrive made by the RUFUS program witch FreeDOS does not want to boot.
            • Dominiks1980
              • Nov 2023
              • 14
              • Polska
              #406
              I uploaded the BIOS to my laptop from another laptop, which I found in this topic, and there is still no DMI, is it possible that the BIOS chip is damaged?
              • peste
                • Dec 2016
                • 13695
                • ROMANIA
                #407
                you have to pass DMI from your bios to the bios that works..
                • Dominiks1980
                  • Nov 2023
                  • 14
                  • Polska
                  #408
                  I tested to see if DMI will be visible at all and it still isn't. Maybe it's not the BIOS load's fault that DMI is not visible.
                  • peste
                    • Dec 2016
                    • 13695
                    • ROMANIA
                    #409
                    was it explained to you at post #396.. what you didn't understand??
                    • Dominiks1980
                      • Nov 2023
                      • 14
                      • Polska
                      #410
                      And I explained that I did that and still no DMI. SMDFlea also did it with the latest bios and still no DMI. What don't you understand?
                        • 22035
                        Ok,so its your DMI that is corrupted. Flash the bios from this post https://www.badcaps.net/forum/troubl...e5#post1605302 .Look at the picture in that post and compare it with your DMI.
                        • Dominiks1980
                          • Nov 2023
                          • 14
                          • Polska
                          #412
                          All clear. My original Bios is corrupt.
                          On left bios from topic, on right my bios.
                          • Dominiks1980
                            • Nov 2023
                            • 14
                            • Polska
                            #413
                            • boykaz
                              • Nov 2023
                              • Chile
                              #414
                              Re: lenovo IdeaPad S145 bios needed
                              Good morning, I have a problem with the Lenovo S145-14API with the AMD 3020e CPU.
                              Serial number PF2XYJFY.
                              MTM:81UV00AQGJ
                              Model Name:81UV
                              GS440&GS540 NMC511 REV 1.0
                              Bios Winbond 25Q64FWSIQ.
                              Lost my DMI​
                              • boykaz
                                • Nov 2023
                                • Chile
                                #415
                                MTM:81UV00AQGJ
                                Model Name:81UV
                                Lost my DMI​
                                i solved
                                • jhesy1230
                                  • Apr 2018
                                  • 7
                                  • philippines
                                  #416
                                  anyone can send me good bios for this model ideapad s145-14ikb
                                  S/N PF29VAQF
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #417
                                    S/N PF29VAQF
                                    Everything you need is at post post 342 ,there`s a link to a virgin bios and a macro script to copy the DMI (the serial number,windows key) from your backup to the new one.Let us know if you have any problems ,or if you manage to do everything ok.
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
                                  • dreamer_x_x
                                    Ottoman Empire
                                    • Nov 2016
                                    • 18
                                    • turkey
                                    #418
                                    Hello my friends. i need your supports. i have a lenovo s145 but i don't know its model number exactly. its cleaned from back cover. its specs amd a9-9425 cpu and its have external gpu. its problem was flashing power led. i try to flashing another bios , i found working dump but laptop not detected ssd. help me please. i atteched my old orjinal bios ( its not working) , and i attached working bios (i found it on badcaps).
                                    old.bin.rar (not working)
                                    25Q64FWSIG.rar (its working but ssd not detected.)
                                    Last edited by Lisa Su; 01-25-2024, 12:21 PM. Reason: Attached external links to the thread
                                    • peste
                                      • Dec 2016
                                      • 13695
                                      • ROMANIA
                                      #419
                                      the bios that works now, from which model is it?? go back and search for the laptop model, for which you have the functional bios, a bios extracted from the Lenovo website..
                                      • dreamer_x_x
                                        Ottoman Empire
                                        • Nov 2016
                                        • 18
                                        • turkey
                                        #420
                                        İ don't know model number because it erased . Laptop's motherboard model is nm-c171 rev:1 . İ want to replace for dmi from old bios to working bios. May you help me
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                          Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                          09-06-2024, 04:40 PM
                                          09-06-2024, 04:00 PM
