lenovo IdeaPad S145 bios needed
  • kobra
    • Feb 2016
    • romania
    #501
    this laptop came from client that lied to me how the laptop cracked, he sayd he had water damage, the board had very little tracks of liquid and the mosfet from video memory power supply was missing and a small hole in the board, originaly i thought that was the only problem of it but after repairing the power supply i nodest the the laptop in loop reboot with a missing auxiliary votage on processor and no image , just lef turns on for a few second than turns off and again in loop, from this i deduce that this was it iniatial probem, and if it had made a bios update is it posible that the dmi area from original bios to re affected? if yes this means i have to make and EC aswell right? which i cant program this ec cause i dont have the adaptor for keyboard plug programming ffs..
    i have found a post where u made a bios and give that bios and the ec for the same model, i modified the dmi of it anow the charging led is turning on but power wont....
    • kobra
      • Feb 2016
      • romania
      #502
      thank you hoaca388, the laptops charing led now turns on but laptop wont turn on, i have usedthis script as suggested in guide, i have created the directory in C:/ and put the original file and renamed oldbios.bin and the newbios.bin the one hoaca388 gaved and than used the script, writed the chip with newbios.bin and soldered it back and now the laptop is only lighting the charging led,i have wrotedd all i did maybe i have made a mistake somwwhere or not used the right script.. who knows
      • hoaca388
        Badcaps
        • Jan 2022
        • 11717
        #503
        The file I posted was found on Lenovo homepage through your MTM 81MV004RRM number. The original file you posted does not have DMI.
        • marian.pigna
          • Oct 2023
          • 11
          • Argentina
          #504
          Hi guys
          I have the same problem as many of you - flashing white power LED, black screen and no Vddgt power rail, fan spinning, every other rail is present, altough cpucore coil is a bit hot under thermal camera but it delivers 0,94V steady
          I have attached my flash dump.
          Can one of you kind guys give me a good data file
          My laptop is
          Lenovo Ideapad S145-15IWL
          81MV
          MotherboardFv440/FS441/FS540 NM-C121
          Rev 1.0
          2018-12-12
          CPU Core i5 8th gen
          S/N: PF1LA6V2
          MTM: 81MV0027AR
          Thanks in advance!
          Regards!
          • hoaca388
            Badcaps
            • Jan 2022
            • 11717
            #505
            Originally posted by marian.pigna
            Hi guys
            My laptop is
            81MV
            Rev 1.0
            2018-12-12
            CPU Core i5 8th gen
            S/N: PF1LA6V2
            MTM: 81MV0027AR
            Thanks in advance!
            Regards!
            New bios file
            • marian.pigna
              • Oct 2023
              • 11
              • Argentina
              #506
              Originally posted by hoaca388
              New bios file
              thanks a lot!! works perfectly!!! can you give some hints about pages, courses or tutorials to learn how to clean bios files?!
              • hoaca388
                Badcaps
                • Jan 2022
                • 11717
                #507
                https://www.badcaps.net/forum/troubl...rces-and-tools
                • sasalli
                  • Oct 2016
                  • 22
                  • Turkiye
                  #508
                  Hello, liquid damaged, everything cleaned up but led blinks that's all. Thank you.
                  Lenovo IdeaPad S145-15IKB
                  Model name: 81VD
                  S/N: PF21GGB1
                  MTM: 81VD004XTX​
                • xxmiguelxx
                  • Jan 2014
                  • Spain
                  #509
                  Hello and thank you very much in advance. My laptop has the problem of the power LED flashing; I would like to ask you for a BIOS to be able to try to repair my computer.
                  81MV
                  Rev 1.0
                  2018-12-12
                  CPU Core i5 8th gen
                  S/N: PF1K4F7M
                  MTM: 81MV00MKSP​
                  • peste
                    • 12768
                    • ROMANIA
                    #510
                    81MV
                    Rev 1.0
                    2018-12-12
                    CPU Core i5 8th gen
                    S/N: PF1K4F7M
                    MTM: 81MV00MKSP​
                    you have everything you need at post #22
                    https://www.badcaps.net/forum/troubl...e2#post3226977
                    • ismailakyoltr
                      • Mar 2015
                      • 102
                      • TURKEY
                      #511
                      Originally posted by SMDFlea
                      Re: lenovo IdeaPad S145 bios needed
                      S145-15IWL Type 81MV Bios https://www.badcaps.net/forum/showpo...&postcount=338
                      Thank you
                      • batuhanca
                        • Jun 2019
                        • 14
                        • türkiye
                        #512
                        hello friends
                        lenovo thinkpad 13
                        type 20GK S06P00
                        SN:069NQA
                        I need a patched bios file to crack the bios password of this device. I tried the autopacht program but I couldn't create the file. I would be very happy if you could help me. Thank you.
                          • 20842
                          Originally posted by batuhanca
                          hello friends
                          lenovo thinkpad 13
                          type 20GK S06P00
                          SN:069NQA
                          Off topic, please read the thread title lenovo IdeaPad S145 bios needed
                          ​Find a thinkpad 13 topic to post your request in, if you can`t find one then start a new thread.
                          • leometalero
                            LeoArg84
                            • Mar 2021
                            • 9
                            • Argentina
                            #514
                            Please help me. Same problem: LED flashing when turned on, 300mA consumption.
                            I tried the previously mentioned BIOSes, but they don't give an image, as if it doesn't detect the RAM. All sources are working fine.
                            I've been trying different BIOSes for several days.
                            81MV
                            Rev 1.0
                            2018-12-12
                            CPU Core i3 8th gen
                            S/N: PF1MXVJV
                            MTM: 81MV0027AR
                            • peste
                              • 12768
                              • ROMANIA
                              #515
                              81MV
                              Rev 1.0
                              2018-12-12
                              CPU Core i3 8th gen
                              S/N: PF1MXVJV
                              MTM: 81MV0027AR
                              Don't post pictures unless asked...
                              post the contents of the bios chip even if it is corrupted..
                              read the forum rules..
                              https://www.badcaps.net/forum/troubl...ore-posting​
                              • leometalero
                                LeoArg84
                                • Mar 2021
                                • 9
                                • Argentina
                                #516
                                Sorry about the photo, I attached the backup, but it had already been rewritten previously by another technician without preserving the information.
                                thank you!
                                • peste
                                  • 12768
                                  • ROMANIA
                                  #517
                                  thank you!
                                  you have everything you need at post #21...
                                  https://www.badcaps.net/forum/troubl...iwl-bios/page2
                                  • leometalero
                                    LeoArg84
                                    • Mar 2021
                                    • 9
                                    • Argentina
                                    #518
                                    81MV
                                    Rev 1.0
                                    2018-12-12
                                    CPU Core i3 8th gen
                                    S/N: PF1MXVJV
                                    MTM: 81MV0027AR
                                    I've been looking at that post and others about editing the DMI before, but I don't have the dump with the original data... only the data on the back cover. I need help rebuilding the DMI with my serial number and product.
                                    However, the LED is blinking and there's no image. It doesn't even display the product information error.
                                    • peste
                                      • 12768
                                      • ROMANIA
                                      #519
                                      The bios chip must be unsoldered from the board before writing or reading..
                                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                      solder wires between the programmer and the bios chip..​
                                      it's the bios on the site...either you wrote the bios with errors or the laptop has another problem..
                                      • andyrajab
                                        • Apr 2025
                                        • Indonesia
                                        #520
                                        Need Bios Lenovo Ideapad S145-14IWL
                                        Backup file at attach.
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                          Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                          09-06-2024, 04:40 PM
                                          09-06-2024, 04:00 PM
                                          09-06-2024, 03:30 PM
