samsung np305e5a ba41-01822a rev 1,0 I need bios
  • hasanaga_84
    • Jan 2020
    • 36
    • Türkiye
    samsung np305e5a-s02tr
    ba41-01822a rev 1,0 scala3_15/17a I need bios
    thank you
    best regards.
    • 20999
    Re: samsung np305e5a ba41-01822a rev 1,0 I need bios
    Post your bios backup .
    • hasanaga_84
      • Jan 2020
      • 36
      • Türkiye
      old bios dump
        • 20999
        try this one .
        • hasanaga_84
          • Jan 2020
          • 36
          • Türkiye
          thank you
          I will try
          • hasanaga_84
            • Jan 2020
            • 36
            • Türkiye
            try this one .
            thank you working bios
            • Zip
              • May 2018
              • 10
              Many thanks!
              • marcin00015
                • Feb 2023
                • Poland
                It is working.
                I used APTIO 4 AMI FIRMWARE UPDATE UTILITY from the BIOS manufacturer: https://www.ami.com/bios-uefi-utilities/ to flash the BIOS (couldn't find another tool/application to flash firmware)
                In my case I needed to run it under DOS, so I created bootable CD with DOS and added firmware update utility for DOS and binary file with ROM. I booted the CD and launched the utility. The BIOS flashing went smoothly, except the fact I couldn't make backup of ROM and the ROM ID was different, but I did force the flash.
                Thank you SMDFlea for sharing the file with BIOS firmware.
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
