Can someone edit my BIOS & make it working, right now I get all the required voltages, VCORE, CPU, all seems to be perfect But no display at all. The CPU is getting normal Hot, fan runs fine. I am attaching the Original BIOS. Please rectify. Motherboard Type LA-G078P Rev: 1.0 (Used in Hp 15-db0038ca) Thanks
LA-G078P Bios problem
Re: LA-G078P Bios problem
try post # 3Can someone edit my BIOS & make it working, right now I get all the required voltages, VCORE, CPU, all seems to be perfect But no display at all. The CPU is getting normal Hot, fan runs fine. I am attaching the Original BIOS. Please rectify. Motherboard Type LA-G078P Rev: 1.0 (Used in Hp 15-db0038ca) Thanks
https://www.badcaps.net/forum/showthread.php?p=923523Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
