p552la_lj rev 2.1
  • bekirsalman
    • Nov 2016
    • 137
    • turkey
    p552la_lj rev 2.1
    İTE 8585E rom please:Şaşkın:
    Electronicman
    • 21457
    Re: p552la_lj rev 2.1
    Ec . If you`ve soldered a new blank chip it will program itself from the bios at first boot .
    • bekirsalman
      • Nov 2016
      • 137
      • turkey
      thanks it works : Grubu:
      Electronicman
      • Jamescl
        • Feb 2017
        • 28
        • Bangladesh
        thanks
        • mrtlty363
          • Feb 2019
          • 5
          • türkiye
          working
          Last edited by SMDFlea; 06-17-2021, 04:18 AM. Reason: https://translate.google.com
          • oflayan
            • Dec 2020
            • 3
            • Italia
            thanks
            • hasel17
              CH341a can erase and read but can't write and blank check
              by hasel17
              So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
              Code:
              Checking for blank...
              (Press
              10-26-2023, 06:20 AM
            • RetroComputingGrotto
              Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
              by RetroComputingGrotto
              I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
              I've uploaded a video of it happening on YouTube:
              I've taken the monitor...
              01-11-2024, 05:37 AM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
            • Spoonicks
              ASUS VH238T blank screen with backlight
              by Spoonicks
              I am having a problem with a ASUS VH238T.
              The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
              Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
              Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
              07-04-2023, 01:29 PM
            • Kalman27
              Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
              by Kalman27
              We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
              We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
              I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
              Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
              06-17-2025, 05:52 AM
