nuvoton NPCE288
  • basemyounes
    • Sep 2017
    • 79
    • gaza
    nuvoton NPCE288
    please I need datasheet for this IO >>
    NPCE288NA0DX
  • basemyounes
    • Sep 2017
    • 79
    • gaza
    Re: nuvoton NPCE288
    • Mechanicalbytes
      • Apr 2020
      • 30
      • United Kingdom
      Re: nuvoton NPCE288
      Pin out for the NPCE288NA0DX.
      • couillu76
        yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
        by couillu76
        before you start the procedure read the bios eeprom and save it you might need it at the end
        1do not power on your svod yet
        2plug you ribbon 30x0.5 to the left of the keyboard connector
        3test pin with testeur if it beep go to next stage
        4 open svod software select 1.8v
        5 now plug your svod
        6 select nuvoton
        7 plug charger on the board/laptop
        8 press read id
        9 select 256k
        10 read nuvoton
        11 save reading, now unplug the svod
        12 open HxD software and open your 256k file the one you just saved
        13look...
        03-26-2023, 06:19 AM
      • electomech-fixer
        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
        by electomech-fixer
        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
        09-15-2025, 01:42 AM
      • SoulFreeze
        Help finding datasheet for component marked G34662
        by SoulFreeze
        Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
        Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
        Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
        05-01-2025, 03:56 AM
      • Rainbow_Chameleon
        Searching Datasheet for AM113 IC by O2MICRO
        by Rainbow_Chameleon
        I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
        Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
        If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
        On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
        So if anyone has a datasheet or at least...
        01-23-2025, 12:03 PM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
