Need BIOS ASUS TP201SA Rev.D
  • G11NS
    • Jan 2017
    • 65
    • Indonesia
    Somebody help Me please...
    I need some Bios dump for Asus TP201SA, do someone has any backup please..?
  • G11NS
    • Jan 2017
    • 65
    • Indonesia
    Re: Need BIOS ASUS TP201SA Rev.D
    Here's my backup file from No Display unit, maybe someone would to fix and reply....
    Thanks before.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      Try this and response
      • rayshine03121408
        • Feb 2018
        • 97
        • Phillipines
        Good Day Masters! Anyone can remove password of my old BIOS Bin? Thanks in Advance!
        Model: TP201SA-FV0013T
        Board Model: TS201SA Rev. 2.0
        SN: H1NLCX04Z96903G
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • shiyab
        • Sep 2023
        • 1592
        • india
        SN: H1NLCX04Z96903G
        Admin Password : 131526
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • lrouw84
          Asus vivobook s510ua bios changed to x510un
          by lrouw84
          Hi there,
          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
          01-28-2023, 01:31 PM
        • ferah831208
          help with bios decompose for Asus s5506ma
          by ferah831208
          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
          08-24-2025, 05:35 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
