mec 16xx dump with info block
  • ilias7790
    • Oct 2018
    • 36
    • Sverige
    #181
    LENOVO L14S G2 Where is point to connect?
      • 21458
      Re: LENOVO L14S G2 Where is point to connect?
      There is no programmer that supports this chip yet,as you`ve already been told https://www.badcaps.net/forum/showthread.php?p=1108743 .To find the pinout you need the schematic.
      • L1MON1991
        • Jun 2021
        • Argentina
        #183
        Re: mec 16xx dump with info block
        Originally posted by 69d0b913
        Thank you for your time, but I managed to remove the T14 bios password using my RT809H, this machine does everything, you just have to know how to use it, after many tests I discovered some achievements that no one shares.
        Hi! How you removed the password with rf809h? pls help me!!!!
        • 69d0b913
          • Mar 2018
          • 146
          • BR
          #184
          I don't know which machine is trying to remove the password, but if it's the ones in this topic, go back to the beginning of this one Thread, nao tem erro.
          • 69d0b913
            • Mar 2018
            • 146
            • BR
            #185
            very good!
            • gesmat
              • Jun 2019
              • 13
              • Poland
              #186
              Hello, password on T590. I have Vertyanov, read mec1663 epprom area 2kb and write edited bin with same FF inside. Now laptop show me messages like this. Invalid RFID Configuration Area etc. I can't enter to bios settings... Do you have mec 2kb bin without password?
              • black0hackers
                • Jul 2020
                • 367
                Some one can point jtag on X1 gen8?
                GX4A0/GYG50 NM-C881 REV 1.0
                • gesmat
                  • Jun 2019
                  • 13
                  • Poland
                  #188
                  Anyone can remove password from 2kb epprom bin?
                  • novator2007
                    • Oct 2016
                    • 15
                    • mumbai
                    #189
                    Originally posted by RethoricalCheese
                    I just moved reset signal resistor and used keyboard connector to do all the programming. Worked well.
                    Can you please post picture/link of your Keyboard connector board for RT809H?
                    I can find only with 32 Pin connector,but T490 used 40 Pin Keyboard connector
                    • cayenne
                      • Jul 2017
                      • 19
                      • Eesti
                      #190
                      P52 has mec1653, jtag pins are same as other thinkpads.
                      did put the pull up resistor for reset , but Vertyanov_JIG gives error.
                      did anyone managed to read the eprom from P52
                      • dam1inc
                        • Jan 2017
                        • 13
                        I was wondering if it was possible to use rt809h bga63 adapter to read/erase/write mec1663 offline
                        • anhbanxoi
                          • Sep 2021
                          • 178
                          • VN
                          #192
                          Same here. Everything look good but unable to read data.
                          • AAAC
                            • Jan 2020
                            • 458
                            • Mexico
                            #193
                            Assuming everything is OK, I suggest to take a look at motherboard schematic, check JTAG interface, you will see each signal has a PULL-UP resistor which are not populated in motherboard.
                            Now check the programmer to see if it has these PULL-UP resistors on JTAG signals.
                            You may have to add these PULL-UP resistors to motherboard JTAG signals for programmer to work… worth a try.
                            • 69d0b913
                              • Mar 2018
                              • 146
                              • BR
                              #194
                              You don't need a resistor, just jump and read it, if you couldn't read it, you can extract the EC from the original file and then just flash the MEC16xx, nothing more than that. After the procedure you will have to write all the machine information such as the serial number of the machine board and a few more things. Some machines can't read the MEC16xx just write, I had this same experience on a T14 thinkpad, I discovered it after 3 weeks of attempts, so I just wrote it I used the same way I described it above and then I was successful.
                              • anhbanxoi
                                • Sep 2021
                                • 178
                                • VN
                                #195
                                Hi, Can you show me how to extract EC from original file? TIA
                                • cpnetwork
                                  • Mar 2016
                                  • ho chi minh
                                  #196
                                  Thinkpad T15 g2 ... SIO MEC1503 jtag pinout .... help me !! thank all !
                                  • NBel
                                    • May 2016
                                    • 11
                                    • Moldova
                                    #197
                                    Finally, I managed to solve this damn T14 again. Now it works perfectly without a password and without computrace.
                                    Hi, how did you solve 2202 Product Name is invalid error? Playing with Maintenance Utilities 1.11 for hours, programmed B0 and C0 couple of times, programmed band name but error is still here.... Thanks for the help!!!
                                    • EvilBzyk
                                      • 10
                                      • Poland
                                      #198
                                      Originally posted by keczuk
                                      Someone have pinout and photo from resistor move to enable jtag in this carbon ?? X1 Carbon 7th
                                      We create pinout and successfully remove password from GX4A0 GYG50 NM-C881 REV:1.0
                                      More info soon.
                                      • NBel
                                        • May 2016
                                        • 11
                                        • Moldova
                                        #199
                                        Ok, going deeper in the rabbithole of lenovo Maintenance Utilities.))
                                        My laptop is P14s gen1. EC Flashed with rt809f, no problem, same resistor for jtag reset and the same jtag pinout as showed earlier in the topic. Now we need to write serials back, and here is the problem!
                                        Googling this problem lead me to this video https://www.youtube.com/watch?v=U30H3_iNM3k
                                        I am using ThinkPad maintenance utilities 1.11(x64) blabla august.12.2020. First time I didnt have planar service option in the forst menu at all. Ok, I found two files - plnsrv.ini and tpconfig.ini with the utility. but plnsrv.ini doesnt have P14s entry for the model! Ok, notepad and lets add this entry manually. Copied two files on the flash drive in the same folder with boot64.efi and planar service option appeared. But anyway - i am introducing all info - c0, model, kb language, uuid, and after restart - the same 2202 Product name...
                                        Now I am thinking that this utility is too outdated for the p14s... And it looks to me that I am out of options... Maybe somebody have any thoughts? Will be very gratefull....
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #200
                                          This might be a bit newer: https://www.badcaps.net/forum/attach...7&d=1619070280
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
