K556UQ Bios Clear
  • bilen
    • Aug 2014
    • 632
    • istanbul
    K556UQ Bios Clear
    no image after update.
    Is there anyone who can fix the original dump?
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: K556UQ Bios Clear
    Most of your topics starts with that sentence, so stop doing updates man - apparently it's not your passion.
    Yes there is, but if you ask for help be more detailed about the problem.
    So what is the issue this time - slow start, no start at all and no image...?
    Edit:
    Try and leave feedback:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • bilen
      • Aug 2014
      • 632
      • istanbul
      Edit:
      HAHAHA. EVET BUNU YAPACAĞIM
      there was no problem. the update was closed instantly and no more images appeared
      no image.
      The file you shared did not work
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        OK, we'll see
        ...the update was closed instantly...
        Really? I believe you this time , but just in case don't touch any files with the word "update" in the description.
        OK, try this - just to see what will happen, it's a K556UQ dump with dirty ME, but if it's working will clean it later, so it's purely for testing purpose:
        • bilen
          • Aug 2014
          • 632
          • istanbul
          OK, we'll see
          OK, try this - just to see what will happen, it's a K556UQ dump with dirty ME, but if it's working wil clean it later, so it's purely for testing purpose:
          0.28 AMP constant.
          no screen.
          I cleaned the problem in the me area I fixed the problem
          thank you for your help.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            0.28 AMP constant.
            no screen.
            Not a good news, looks like the problem is not bios related this time.
            Do you have a oscilloscope in hand? If yes try to see what's going on with the bios chip, is there any data activity? Or try the the LED method to check, if you don't have it.
            • bilen
              • Aug 2014
              • 632
              • istanbul
              problem bios.
              clear me region
              fixed
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                problem bios.
                clear me region
                fixed
                Fine, if it's fixed most probably the problem was with the bios programming - always use verify option, than read the chip again and compare the files (once again) to make sure everything is ok.
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • al3m0di
                  Update bios EFCN58WW to EFCN59WW
                  by al3m0di
                  Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                  I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                  The BIOS version is EFCN58WW.
                  When I turn on the device, it displays the message:
                  "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                  The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                  I've tried
                  07-29-2024, 10:32 AM
                • Focus2005
                  HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                  by Focus2005
                  Hello everyone.
                  I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                  05-01-2025, 05:41 AM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
