Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Need help for Bios Dump Asus K401UQK Rev 2.0
  • Sparo
    replied
    Originally posted by ismailakyoltr
    That's what I couldn't figure out: 123455 and 12345. / I know the BIOS file is usable. We use it too. But in these cases, do the serial and MAC addresses cause any conflicts or problems? Could you provide some information?
    Well You said you already transferred your DMI so it should work fine
    But if anything seems off you can always revert back to your original BIOS file
  • ismailakyoltr
    replied
    Originally posted by Sparo
    What couldn't you decode I don't understand the passwords were 123455 and 12345
    Anyway here they are in case someone wants to use your BIOS dump to fix their machine later on (since this is a community)
  • Sparo
    replied
    I uploaded an encrypted BIOS.
    model : K401UQ
    seri no : H6N0CX11W838248 (K401UQK)
    Just so you know, I couldn't delete the password by changing the amitsesetup section to 00 00 00.
    commented on 's reply
    You`re welcome :-)
  • ismailakyoltr
    replied
    Originally posted by SMDFlea
    try this bios.
    Thanks. Great, no password needed. Also, Windows was installed in CSM mode and wouldn't start. But now it starts. DMI transfer solved the problem in Windows.
    replied
    The site has become paid; I hope I can download it. I uploaded an encrypted BIOS.
    model : K401UQ
    You prepare the file, and I'll try to complete the purchase.
    try this bios.
    Premium supporters get full download access and other benefits.
  • ismailakyoltr
    replied
    Hi and No the password will not come back if you transfer back your DMI
    You can post your BIOS file to unlock instead (But also Post the Serial Number)
    model : K401UQ
    Last edited by ismailakyoltr; 04-15-2026, 05:29 AM. Reason: Password reset additional information.
  • Sparo
    replied
    Hello. K401UQK has a password-protected BIOS on the model in question. I downloaded a BIOS file from Asus, deleted the first 800, and took the 200000 partition from the old BIOS. The password is gone, and the computer boots up. However, I'm not entirely sure where the DMI partition is located. Also, if I transfer the DMI file, will the password come back?
  • ismailakyoltr
    replied
  • antskull
    replied
    Re: Need help for Bios Dump Asus K401UQK Rev 2.0
    thanks.. it works
  • M4n0l0307
    replied
    Originally posted by peste
    try...extras from the Asus site ...
    Thanks Friend !
  • _F.fernan
    replied
    Thank you peste . works on mine
  • jakir1999
    replied
    thank you..peste
  • G11NS
    replied
    Thanks for Help...I'll try it.
  • peste
    replied
  • G11NS
    replied
    put the backup bios here
    Here My Bios backup...Hope your help Please....
  • peste
    replied
  • G11NS
    started a topic Need help for Bios Dump Asus K401UQK Rev 2.0
    Please Help Me.....
    I need Bios Dump for Asus K401UQK Rev 2.0....
    THANKS..
  • ronaldopdias
    ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
    by ronaldopdias
    I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
    • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
    • BIOS file downloaded directly from the official ASUS support page.
    • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
    Issue:
    The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
    Because FlashBack didn’t work, I:
    • Removed the BIOS SPI IC from
    02-04-2026, 03:16 AM
  • kinojk2
    ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
    by kinojk2
    Hi, Thanks for all you do here.
    I have attached my 16MB dump.
    EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
    EDIT:
    I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
    The clips are such a pain to use, soldering would be a great skill to have.
    Thanks for the advice in other threads!
    To answer my own question, I didn't...
    03-24-2026, 05:55 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • gandamonteiro
    ASUS A407UB (36AM1SB1) Rev 2.0 – Full 8MB BIOS Dump Request
    by gandamonteiro
    Hello.
    I am looking for a FULL 8MB BIOS dump for:
    ASUS A407UB
    Board: 36AM1SB1
    Rev: 2.0
    The laptop has no 3.3V rails after a bad BIOS flash.
    Originally the board powered on abnormally (CPU heating as soon as adapter was plugged).
    After flashing an incomplete BIOS image, the board is now dead (no 3.3V, no boot).
    What was tried:
    - Read BIOS guides and recovery methods
    - Used official ASUS BIOS file (partial image)
    - Tried flashing with external SPI programmer
    - Recovery was not successful
    Request:...
    12-21-2025, 09:01 AM
