ThinkPad Thunderbolt 3 Firmware
Go into bios settings and check if TBT assist is enabled or not. Backup the current TBT firmware , use a new chip. The firmware at post 1 needs padding out to 1MB using a hex editor.Comment
TBT assist was disabled. I have enabled it and tested it, still the same issue (I presume it is better to be enabled). Just to double check this is the correct chip?Comment
I don`t know if that`s the right one, you can check with the schematic if there is one , or make a backup and post i`ll check it.
Guys i have Lenovo T480s that wont charge battery and windows shows thunderbolt error. I flashed U12 with TBT.bin from update and now windows dont shows error no more. but battery is still not charged and stays at 0%, 12.5V. Should i try change battery or flash Assist.bin? or any other hint?
no hint?Guys i have Lenovo T480s that wont charge battery and windows shows thunderbolt error. I flashed U12 with TBT.bin from update and now windows dont shows error no more. but battery is still not charged and stays at 0%, 12.5V. Should i try change battery or flash Assist.bin? or any other hint?Comment
by Maxpower3Info for error 2202 LenovoThinkPad models and type
Extract from ThinkPad Maintenance Utilities Configuration File
plnsrv.ini Version 1.01
Some information that may be useful
There must also be missing models, add them to the list if you know of any.
...Code:brand name 20B1=ThinkPad Edge E445 20B2=ThinkPad Edge E545 20BC=ThinkPad Edge E145 20BM=ThinkPad X140e 20BL=ThinkPad X140e 20A3=ThinkPad X230s 20AH=ThinkPad X230s 20AK=ThinkPad X240s 20AJ=ThinkPad X240s
Channel: BIOS Requests ONLY!
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by TamFisheHi there, I have a ThinkPad X1C6 which I got cheap from a friend as I've mentioned before if you decide on checking my profile, but it has issues, including both the bios and thunderbolt firmware bricked. So far, I got a 20KG bios from indiafix, however, I still haven't figured out how to fix the thunderbolt firmware issue ( I feel like mentioning that I've never worked with FL1 and FL2 files or with any Lenovo product and I'd wish to not brick something beyond repair. ). Can someone with this same model of laptop give me a thunderbolt dump of the chip (Winbond W25Q80 ONLY) and compare my dump...08-24-2025, 03:08 AM
by 77mike77Hello, I need a clean BIOS dump for a Lenovo ThinkPad L13 Yoga Gen 3, Type 21B5 (Intel). BIOS is bricked after failed update. Main chip is GigaDevice 25B256EY1G (labeled BIOS2, 32MB). I will use a CH341B programmer with SOIC8 clip. Thank you....
by zrb1qyvtvHi,
I didn't find a request for this specific SKU yet, but... I need the bios password removed from it.
(The tamper protection triggered randomly one day)
Here's as much info as possible about it:
- ThinkPad X13 Yoga Gen 1 (Type 20SX)
- SN R90YLACQ
- Model 20SX002XGE
- CPU 10th Generation Intel® Core™ i7-10510U
- Lenovo-Support page for convenience
And here are what should be valid EC and BIOS dumps (from an external reader)...-
- Loading...
