Laduree-SKY MB 448.06202.0011 14263-1 BİOS
  • hoaca388
    Badcaps
    • Jan 2022
    • 11726
    Re: Laduree-SKY MB 448.06202.0011 14263-1 BİOS
    Originally posted by Infinity13197
    laduree-sky mb 14263-2 448.06202.0021
    Some should help me and download this exact same file, my credit on premium side has finished will really and very much appreciate if I can get it as soon as possible!!
    Serial number ?
    • chth96
      How Can I test PWM DM0365R?
      by chth96
      Hello
      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
      06-18-2025, 04:14 PM
    • GameKinq
      6-71-nj5l0-d02 - exa nj51lu backup test ok
      by GameKinq
      6-71-NJ5L0-D02 - EXA NJ51LU BACKUP TEST OK
      SRG0S (Intel Core i3-1005G1)-CPU...
      05-31-2022, 07:55 PM
    • khelane
      test active pfc power with lamp test
      by khelane
      Hello
      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
      Is there a way...
      06-03-2025, 01:00 AM
    • chronic519
      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
      by chronic519
      Hello.
      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
      Found issue with a RAM block
      Replaced, green lines gone.
      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
      Used a good card to test and same results low errors 32+.
      I am just search for some form of command to do a full test on the GPU.
      I just ran the mats command with my good GPU and passed after roughly 40 min.
      The repaired one, ran...
      05-20-2025, 07:56 PM
      APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
      by sam_sam_sam
      This started a few days ago and does this about every 8 hours
      After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
      The battery backup is about 3 or 4 years old
      Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
      06-02-2024, 02:30 AM
