ACER A314-32 bios needed
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need a working bios on ACER A314-32 DA0Z8GMB8D0 REV MODEL: Z8G please! the problem stuck on acer logo then shuts down and restart. go to bios menu there is no option can enable UEFI AND LEGACY option.I have attached the original corrupted bios, can someone fix this please
  • peste
    • 12593
    • ROMANIA
    Re: ACER A314-32 bios needed
    try...
    • String2016
      • Nov 2015
      • 2229
      • philippines
      @peste i try your bios but still the same issue acer logo shows up then shuts off and restart, when i go to bios menu still no option to change uefi to legacy
      • String2016
        • Nov 2015
        • 2229
        • philippines
        need help please
          • 20643
          try this one,your win key included.
          W 385000h
          • String2016
            • Nov 2015
            • 2229
            • philippines
            still the same issue secureboot on the bios menu cannot change
            • String2016
              • Nov 2015
              • 2229
              • philippines
              anyone have a working bios on this the problem is turns on boots fine on acer logo then shuts off and restart but when i go to bios menu i cannot change the options on uefi to legacy it just disabled. here it is only showing
                • 20643
                The bios i posted was extracted from acer bios update. There shouldn`t be any problem. Try bios setting with and without the hard drive
                • String2016
                  • Nov 2015
                  • 2229
                  • philippines
                  already tried that without hard drive above picture showing
                    • 20643
                    Post your EC backup .
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      If you want to disable SecureBoot you may need to set a supervisor password and reboot. Or just leave it enabled and boot on an official Windows (7, 8 or 10 64-bit) media in UEFI mode.
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        True, on some Acer models including this one if you want to change SecureBoot option, supervisor password must be enabled first.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • String2016
                          • Nov 2015
                          • 2229
                          • philippines
                          problem solved burning uefi flash drive thanks all for the help
                          • joeycuadr
                            • Jul 2016
                            • phillipines
                            EC backup A314-32 password problem
                            • aprilbg087
                              • Feb 2018
                              • 30
                              • Philippines
                              W 385000h
                              this works perfect
                              thank you
                              • technician37
                                • Aug 2018
                                • 30
                                • philippines
                                verywell said sir..
                                • tribalcore20
                                  • Jun 2020
                                  • 66
                                  • Philippines
                                  Looking for bios bin acer 3 a314-32
                                  Acer aspire 3 a314-32
                                  Model no: N17Q4
                                  Motherboard: DA0Z8GMB8F0 REV: F
                                  • piszpunta
                                    • Jan 2019
                                    • 249
                                    • poland
                                    Re: Looking for bios bin acer 3 a314-32
                                    try
                                    • tribalcore20
                                      • Jun 2020
                                      • 66
                                      • Philippines
                                      Did not much id sir.
                                      • rudi.ssc
                                        • Feb 2019
                                        • Indonesia
                                        is it work?
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                        • NecroFlex
                                          Acer Aspire 1 A115-32-C28P BIOS needed please
                                          by NecroFlex
                                          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                          02-11-2025, 08:51 AM
                                        • Wg188
                                          ACER Veriton Z4660G AIO bios help
                                          by Wg188
                                          I have an Acer veriton Z4660G all in one pc,
                                          Model: Z4660G-I5850H1 (VZ4660G_W)
                                          Need bios dump and schematic would save my life !
                                          to make a long story short I bought this all in one used
                                          with a broken lcd, with the objective of making a custom desktop out of it
                                          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                          06-17-2023, 02:20 PM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • James194zt
                                          Acer Nitro 50-640E Corrupted BIOS Dump
                                          by James194zt
                                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                          04-28-2025, 03:29 PM
