Dell Latitude 7400 Bios Password
  • bitsandbytes206
    • May 2014
    • 7
    • US
    #541
    Hi I need 8fc8 bios unlocked for Dell latitude 7400 st: 7BZJ8Y2 mobo: EDC40 LA-G871P Rev 1.0 A00
    Attached is original dump from UC5 MX25L25673G
    • Markus1741
      • Sep 2020
      • 843
      • N/A
      #542
      Hello, your bios is corrupted. Read again.
      • bitsandbytes206
        • May 2014
        • 7
        • US
        #543
        Oh no, that was verified before rewriting. Can I take a dump from different machine but same model?
        • Markus1741
          • Sep 2020
          • 843
          • N/A
          #544
          Yes, if you clean the ME region it works.
          You can also build a new one.
          There is no information such as Windows Key Service Tag stored in your BIOS file.​
          • abudo
            • Jan 2020
            • 29
            Hello everyone I need help to remove BIOS password
            Dell Latitude 7400
            Service tag HN4H353
            Board ID LA-G871P
            Thank you.
              SMDFlea commented
              Editing a comment
              Thread merged.
          • rex98
            • Feb 2023
            • 1277
            • Mandaue CEBU, Philippines
            #546
            Dell Latitude 7400
            Service tag HN4H353
            Board ID LA-G871P
            Thank you.
            1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
            • Markus1741
              • Sep 2020
              • 843
              • N/A
              #547
              Unlocked file ....
              • abudo
                • Jan 2020
                • 29
                Unlocked file ....
                hi I just flashed the BIOS file. I cant turn on the laptop hehehe I will try the other file. I also noticed another 2 winbond chip. should I also post the dump of those 2?
                • Markus1741
                  • Sep 2020
                  • 843
                  • N/A
                  #549
                  • rex98
                    • Feb 2023
                    • 1277
                    #550
                    our patched are both the same i compared in hex editor. check your solder. or your backup maybe corrupt
                    • Markus1741
                      • Sep 2020
                      • 843
                      • N/A
                      #551
                      Hello rex98, thank you for your correction, I have already compared yours and my BIOF file and of course found that our two files are identical.
                      It was too tedious for me to comment on it because we both don't know what skills the user has, how good their soldering skills are or the like.
                      I think what most people forget is to do the steps described in the Dell article.
                      https://www.dell.com/support/kbdoc/e...n-dell-systems
                      Because the manipulated patch resets everything to the beginning.
                      So I always do it as described by Dell and have no problems.
                      • abudo
                        • Jan 2020
                        • 29
                        thanks rex98 and Markus1741 im going to resolder the chip. Also I deleted the existing BIOS before flashing the patched and unlocked BIOS. Would that affect the process too?
                        • abudo
                          • Jan 2020
                          • 29
                          if incase my backup maybe corrupted is there another way to fix the problem? thanks you very much for you reply.
                          • abudo
                            • Jan 2020
                            • 29
                            Thanks for the reply Markus1741 I am 99.99% sure with that solder hehehe but I will still resolder the chip. They are not that hard compared to mobile phone chips. In case my BIOS backup file was corrupted, is there any way to fix the problem? Thanks for you reply.
                            • Markus1741
                              • Sep 2020
                              • 843
                              • N/A
                              #555
                              Oops, I once compared your original uploaded file with a file from me without a PW and in my opinion it is defective.
                              There are too many inconsistencies listed.
                              The second picture should show yours with PW on the left and mine without PW on the right.
                              Now you need a new BIOS file, I can build a new one, but from experience it's unlikely that that will solve the problem.
                              Second choice is a ME region cleaned file, Dell is not that picky.​
                              • abudo
                                • Jan 2020
                                • 29
                                can you give me idea on how to aquire those 2 or can you help me get those file. Appreciate your help
                                • Markus1741
                                  • Sep 2020
                                  • 843
                                  • N/A
                                  #557
                                  Hello, this BIOS is mine, I'm pretty sure it didn't have a password.
                                  Try it otherwise we will patch it again.
                                  • abudo
                                    • Jan 2020
                                    • 29
                                    hi I tried to click verify after flashing and im getting this error (attached). Is this something I need to worry about?
                                    • Markus1741
                                      • Sep 2020
                                      • 843
                                      • N/A
                                      #559
                                      Just try NeoProgrammer, your programmer software can't handle the chip.
                                      I would also invest in a T48 or RT809F or RT809H programmer, they come with their own software.
                                      • abudo
                                        • Jan 2020
                                        • 29
                                        i dont know how to thank you. Its working now using neoprogrammer. Thank you very much for your time. How can I buy you a beer? hehehe
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • jhanra
                                          by jhanra
                                          11-02-2024, 04:19 AM
                                        • anlsmith
                                          Dell Latitude 5430 Bios Password
                                          by anlsmith
                                          I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                                          08-31-2024, 08:46 PM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • iwu
                                          Dell Latitude 5520 - dump bios to obtain password
                                          by iwu
                                          I am not experienced in electronics, but I really want to check if my idea is possible.
                                          I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                                          BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                                          There was no computrace activated.
                                          I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                                          1. I do not know how thebios...
                                          04-14-2024, 04:10 AM
