Dell Latitude 7400 Bios Password
  • epicsmith
    • May 2022
    • usa
    #281
    Re: Dell Latitude 7400 Bios Password
    Can i get master password for G9CL793-8FC8
    • aissa med
      • Mar 2018
      • morocco
      #282
      Post your BIOS dump
      • tdot_steel
        • May 2022
        Can I get master password for 5KSD6D3-8FC8 please?
        • satishkumar
          • Sep 2015
          • 164
          • India
          #284
          post ur laptop bios backup
          or try
          https://bios-pw.org/
          • feherhollo
            • Nov 2019
            • 110
            • Hungary
            #285
            Can you unlock my locked dump? 8FC8
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #286
              Become a Badcaps supporter
              Thanks to all supporters.
              • feherhollo
                • Nov 2019
                • 110
                • Hungary
                #287
                Originally posted by Vesko356
                Laptop won't turn on, Just caps lock led on.
                What is the problem? Itry to reflash
                • feherhollo
                  • Nov 2019
                  • 110
                  • Hungary
                  #288
                  Unfortunately your file not working. Original file is ok. I have tested it.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #289
                    Should work, most probably you didn't programmed the chip properly (with verification) or didn't solder the chip as it should.
                    Try again.
                    • feherhollo
                      • Nov 2019
                      • 110
                      • Hungary
                      #290
                      Try again.
                      I reflashed the chip. Verified ok. Now working just high ventilation in factory mode which was confused me. Everything okay now. I'm happy that you erased the service tag region also. Very good work. Many thanks
                      • sosphemy
                        • Jun 2022
                        • Mexico
                        #291
                        where can I contact you?
                        I need to unlock a Dell Latitude 7400 Laptop.
                        59VBYY2-8FC8.
                        Please
                        • ForestFan
                          • Jun 2022
                          #292
                          Can anybody help with the bios admin password for my 7400?
                          System Number: 8SFJ1Z2-8FC8
                          • feherhollo
                            • Nov 2019
                            • 110
                            • Hungary
                            #293
                            59VBYY2-8FC8.
                            Please
                            You need to dump your bios chip content and reflashed the chip using patched content. Master password not available for free.
                            • feherhollo
                              • Nov 2019
                              • 110
                              • Hungary
                              #294
                              You need to dump your bios chip content and reflash the erased chip with patched content. Master password not available for free for these new 8FC8 suffix...
                              • 8bit4k
                                • May 2022
                                • El Salvador
                                #295
                                Hello i have a 8f8c -Latitud 7400 and reader CH341A any tutorial to read dump please ?
                                • anshad
                                  • Nov 2010
                                  • 249
                                  #296
                                  There are plenty of demo videos available in the Youtube.
                                  https://www.youtube.com/watch?v=4qX2zihB6UE
                                  If you haven't purchased the programmer yet, i would highly recommend the upgraded version which has proper volt setting is available. Older black PCB one is not that reliable and need a hardware mode to make it compatible with some chips.
                                  https://www.youtube.com/watch?v=7_mnuuXyPiI
                                  In my experience, CH341A is a very reliable SPI programmer. What gave it a bad reputation is the usual way of using a clip to read the chip on board. This is a very unreliable method with any SPI programmer - even with costly programmers, reading and writing with the clip is a headache.. If you have good soldering skill, desoldering the chip and use a compatible SPI adapter is the best way. Otherwise you can try with the clip. In any case, you should read the chip multiple times and verify the checksum of all.
                                  • CammyTier1
                                    Tier 1 Assets
                                    • May 2022
                                    • 43
                                    Could someone please remove pass for me thanks in advance
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11733
                                      #298
                                      Removed
                                      • CammyTier1
                                        Tier 1 Assets
                                        • May 2022
                                        • 43
                                        Originally posted by hoaca388
                                        Removed
                                        Thanks mate any chance u could explain what u do to unlock them i have like 10 - 15 off them that i will need to do after i replaced screens on them
                                        • biosedit
                                          • Sep 2018
                                          • 60
                                          • Pakistan
                                          #300
                                          please remove password from dump
                                          e7400
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • anlsmith
                                            Dell Latitude 5430 Bios Password
                                            by anlsmith
                                            I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
                                            08-31-2024, 08:46 PM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • iwu
                                            Dell Latitude 5520 - dump bios to obtain password
                                            by iwu
                                            I am not experienced in electronics, but I really want to check if my idea is possible.
                                            I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                                            BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                                            There was no computrace activated.
                                            I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                                            1. I do not know how thebios...
                                            04-14-2024, 04:10 AM
