lenovo t440p bios password
  • Grigan27
    • Apr 2023
    • 7
    • France
    #121
    Re: lenovo t440p bios password
    Hi, all clips are clamps it seems very well attached but maybe you are right, i will re-test using a multimeter right now to be 100% sure. Since i had the same issue with the original clip i was thinking there was something specific with this chip
    • Grigan27
      • Apr 2023
      • 7
      • France
      #122
      So the connection of those HP clamp are really perfects, even by moving them it's stable. You were right about the cabling, i reverse pin 5 to 8 (i put 8 to 5). shame on me. Great thanks for your help
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #123
        You're welcome.
        Yes the image was good, so I was able to track the positions of the cables.
        Become a Badcaps supporter
        Thanks to all supporters.
        • Grigan27
          • Apr 2023
          • 7
          • France
          #124
          Now it detects properly the chip however, with the software programmer i got from the forum it's not reading properly the contents (only FFFF).
          I was able to use another software (Asprogrammer) that succeed to get the data however when i try to use lenovo_autopatch it's reporting it as "corrupted" bin. I will continue investigation a few more evening and keep you in touch
          • Grigan27
            • Apr 2023
            • 7
            • France
            #125
            I finally succeed to read/backup/patch with the CH341A programm v1.29. the lenovo_autopatch worked perfectly. Thanks! For un unknown reason, after i've applied the patched_bios, i was not able to re-read it the chip (empty) however i was able to re-write the original bios. Maybe a bad connection? anyway, now the sup password has gone
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #126
              You're welcome.
              Most probably bad contact, also you can use NeoProgrammer V2.2.0.10 with your ch341a, for best results with this programmer.
              Please consider donation in support of the "Bios Requests" section of the forum.
              • levelpulse
                • Sep 2023
                • united kingdom
                #127
                My T440p has a supervisor laptop. I've downloaded it and patched the bios with the whitelist.
                Wondering if anyone can help me remove the supervisor password.Would be greatly appreciated, thanks!
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #128
                  Read the rules before posting:
                  BIOS guides, methods, resources and tools
                  https://www.badcaps.net/forum/showthread.php?t=103526
                  Password removal by laptop brand
                  https://www.badcaps.net/forum/showth...42#post1108842
                  • Joel Suarez
                    • Jan 2024
                    • 5
                    • Costa Rica
                    #129
                    [CITA=AhorroCuenta; n1671993]Lenovo Thinkpad T440P - Volcado de BIOS ? (NM-A131)
                    Hola a todos.
                    Tengo en mis manos un Lenovo Thinkpad T440P, que estaba bloqueado con SVP. Intenté con el controlador UEFI DXE de parche automático, pero no obtuve ningún resultado.
                    Pero, ahora el problema a pesar de que se verificó dos veces cuando desoldé ambos chips BIOS.
                    La computadora portátil no se enciende. Es un FAN ciclista.
                    Pero estoy bastante seguro de que es el BIOS el problema, porque hace minutos funcionaba bien, antes de que sonara el -flash- del autopatcher, BIOS.
                    Traté de volver a poner el viejo, pero nuevamente nada.
                    Así que estoy adjuntando los archivos del BIOS. [/CITA]
                    Hola, ¿encontraste alguna solución?
                    Yo tengo el mismo problema
                    QUOTE=SavingAccount; n1671993]Lenovo Thinkpad T440P - BIOS Dump ? (NM-A131)
                    Hi everyone.
                    I have in my hands a Lenovo Thinkpad T440P, which was bricked with SVP. I tried with the auto-patcher UEFI DXE driver, but got no result.
                    But, now the problem even though it was double-checked when I unsoldered both BIOS chips.
                    The laptop won't turn on. It's a cycling FAN.
                    But I'm pretty sure it's the BIOS that's the problem, because minutes ago it was working fine, before the autopatcher -flash- sounded, BIOS.
                    I tried to put the old one back, but again nothing.
                    So I'm attaching the BIOS files. [/QUOTE]
                    Hi, did you find any solution?
                    I have the same problem​
                    • Joel Suarez
                      • Jan 2024
                      • 5
                      • Costa Rica
                      #130
                      Hola amigos,traté de seguir las recomendaciones en el foro,
                      pero cuando flasheo la BIOS de 4mb y 8bm y vuelvo a encender mi computadora no me da una imagen y el ventilador se enciende durante dos segundos y se vuelve a encender y se queda así en un ciclo y adjunté mis archivos originales.
                      ¡Gracias de antemano por toda su ayuda
                      Hi guys, I tried to follow the recommendations on the forum,
                      but when I flash the 4mb and 8bm BIOS and turn my computer back on it doesn't give me an image and the fan turns on for two seconds and turns back on and stays like that in a cycle and I attached my original files.
                      Thanks in advance for all your help​
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11815
                        #131
                        English , please !
                        • peste
                          • 12887
                          • ROMANIA
                          #132
                          post the S/N, the full name and model of the laptop,,the motherboard model, etc.
                          • Joel Suarez
                            • Jan 2024
                            • 5
                            • Costa Rica
                            #133
                            Hi thanks for your help
                            Sorry, thanks for the help
                            The computer is a Lenovo Thinkpad T440P
                            The motherboard model is: VILTT2 NM-A131 Rev : 1.0
                            but when I update the BIOS from 4MB to 8MB and turn my computer back on I get no image and the fan turns on for two seconds and turns on again and stays like that in a cycle and I attached my original files.
                            Thanks in advance for all your help.​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11815
                              #134
                              Serial number ?
                              • Joel Suarez
                                • Jan 2024
                                • 5
                                • Costa Rica
                                #135
                                Originally posted by hoaca388
                                Serial number ?
                                • Imran Mughal
                                  • Jun 2024
                                  • usa
                                  #136
                                  Please help unlock 4med t440p bios file (supervisor password unlock)
                                  • sahilkumar
                                    • Apr 2024
                                    • 20
                                    • India
                                    #137
                                    try
                                      • 21040
                                      Thread merged. Read the rules ,please post the laptop serial number ! https://www.badcaps.net/forum/troubl...before-posting
                                      • Imran Mughal
                                        • Jun 2024
                                        • usa
                                        #139
                                        TYPE: 20AN-00DEUS
                                        S/N: PC-08U7DT
                                        • Imran Mughal
                                          • Jun 2024
                                          • usa
                                          #140
                                          Originally posted by sahilkumar
                                          try
                                          Doesn't work. Computer attempts to boot. Power light blinks as if computer has rebooted. Continuous cycle.
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • baaligoga
                                            Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                            by baaligoga
                                            Good day, everyone!
                                            I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                            I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                            05-20-2023, 09:48 AM
                                          • darknwo
                                            Bios password Lenovo Legion 16IRX8H
                                            by darknwo
                                            Hi, can someone help me please with the removal of the bios password of this dump.
                                            Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                                            For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                                            Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                                            10-05-2024, 10:40 AM
