hp 840 g6 6050A3022501-MB-A01
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: HP Elitebook 840 G6 Admin PW Help
The 16mb chip however doesn't have the pads so I will have to remove it. But I don't have the adapters to read it.
So instead of trying to remove the chip and reading/writing. I just want to break the laptop.
I have wiped the 32mb chip, but after a few reboots the machine restores the bios again.
What can I do to damage the laptop so it gets the motherboard replaced but not void the warranty?Comment
The 32mb chip is also a WSON-8, but it had pads so I was able to solder wires to it and read/write it without removing it from the board.
You can trace the tracks if you zoom in with a camera, but they lead to the smallest SMD I've ever seen, and I am not able to do that kind of work.
I did use a heat gun and removed the chip. I soldered wires to but unable to read or write using the programmer.
So the lesson is the HPs with 1 bios chip is fine and I can do those no problems at all ... the ones with 2 is way beyond my skills.
Thanks again for your help everyoneComment
I've looked at that and I don't have the skills or equipment to do that.
NeoProgrammer, a good CH341A software alternative supports the chip - https://www.badcaps.net/forum/showpo...04&postcount=7 .Use the IC search,just type in 25LPComment
Re: hp elitebook 840 g6 bios password
https://www.badcaps.net/forum/showth...ghlight=840+g6
My bad ,, read over here ... there is another SPI Chip ,, 16MBComment
My bad ,, read over here ... there is another SPI Chip ,, 16MBDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Last edited by SMDFlea; 04-07-2023, 01:46 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Problem with elitebook 840 g6 bios
Hello, i need to remove password Hp elitebook 840 g6.
After trying to program with known good bios with org me region it works without password but hp endpoint problem shows on boot.
Posting org dump files 32mb and 16mb.Attached FilesComment
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
- Board: SU_GN100_MB_V12_20231120A
- Serial: GN10Q12124205W1588
- Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
Today, 09:41 PM -
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
- Loading...
