EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
  • rookie_badcaps
    • May 2015
    • 12
    • philippines
    #81
    Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
    @mferna14
    thanks , serial ,re-edited in post\
    \sn:c02nc88mg086
    thanks in advance
    • mferna14
      • Jun 2018
      • 1007
      Here you go with your serial # C02NC88MG086 provided & for EMC 2632. ME Region cleaned & Serial Number Updated.... Good luck
      • hamzafox
        • Nov 2019
        • 81
        • SYRIA
        #83
        MacBook Air A1466
        820-3437-B please clean me bios
        • mferna14
          • Jun 2018
          • 1007
          You did not take the backup correctly... Kindly use the correct tools to read the BIOS well. Nothing there on this zip file... If you cannot do, just provide Serial # & the EMC # on the back of the cover. Will do it for you
          • hamzafox
            • Nov 2019
            • 81
            • SYRIA
            #85
            S/n c02n6ee3g085
            • hamzafox
              • Nov 2019
              • 81
              • SYRIA
              #86
              S/n c02n6ee3g085
              EMC 2632
              • mferna14
                • Jun 2018
                • 1007
                Here you go.. with your EMC & Serial # update... Report pls. if all works fine. Thanks
                • hamzafox
                  • Nov 2019
                  • 81
                  • SYRIA
                  #88
                  Thank you but The problem is still the same, the device works very slowly and turns off after about 15 minutes
                  • mferna14
                    • Jun 2018
                    • 1007
                    Problem somewhere else, check all power rails in sequence... You are surely missing one rail or a Liquid spill/corrosion on a component. I have a similar problem like this & there was a corrosion on one of the resistence near the SMC.. Check carefully under the MS.
                    • hamzafox
                      • Nov 2019
                      • 81
                      • SYRIA
                      #90
                      Thank you, the problem has been solved. I found a capacitor exposed to moisture NEAR the SMC THANK YOU
                      • mferna14
                        • Jun 2018
                        • 1007
                        WELL DONE!!!! Great Trouble Shooting & hope all learn from this case study...
                        • bari
                          • Sep 2022
                          • pakistan
                          #92
                          not ok
                          • ViLex
                            • Dec 2022
                            • 6
                            • Russia
                            #93
                            Good afternoon.
                            I really need help. The problem is as follows:
                            I bought a laptop, it was on a password (not EFI) and on icloud, the SSD worked, everything was fine, but on a password (. A friend said that the BIOS firmware would solve the problem. I downloaded it somewhere, flashed it and the laptop didn't turn on. The old BIOS firmware was considered incomplete and became non-working. I found firmware 118.0.0.0.0 in this branch (and tried 117.0.0.0.0) (a1466+9.5.3.1526+outimage.rar ), changed the serial number according to the instructions. Flashed, there are no passwords, but does not see the SSD. The disk is working. I put another working disk - also does not see (. What could be the problem? Maybe the firmware didn't fit me? The external disk sees via USB, I boot up, the internal disk does not see in the Disk utility (. mac OS put Maverik, BigSur on the external disk, it did not help ( SMC and PRAM have already been reset 50-60 times (. Nothing helps (. HELP, PLEASE. What did I do wrong?
                            so, I have a MacBook Air 6.2 13 2014, 820-3437-B EMC 2632, MD760RU
                            s/n: C17MLQY7G085
                            • mferna14
                              • Jun 2018
                              • 1007
                              @ ViLex., dear we are here to help you out till the end, no worries. Try this updated file, I have re-programmed the BIN file according to your serial number & CleanMe done. Try it & inform us.. Thanks
                              • ViLex
                                • Dec 2022
                                • 6
                                • Russia
                                #95
                                Thanks. I'll try it today, I'll unsubscribe
                                • ViLex
                                  • Dec 2022
                                  • 6
                                  • Russia
                                  #96
                                  no, it didn't help (. The disk also does not see
                                  • mferna14
                                    • Jun 2018
                                    • 1007
                                    What disk do you not see, though all this is scripted in Russian, I see all your drives, What do you want to do next??? I see you SSD/HDD & media drive, all seems to be ok. Just inform us what you want to do next... This is not a BIOS error, BIOS is ok.
                                    • ViLex
                                      • Dec 2022
                                      • 6
                                      • Russia
                                      #98
                                      the laptop is loaded from an external ssd, the internal drive is not visible. Power is supplied to the internal disk, the internal disk is original, working (I checked Air on another and formatted it into the GUID Partition Scheme). In the photo you and I see only an EXTERNAL disk
                                      • mferna14
                                        • Jun 2018
                                        • 1007
                                        I checked the photo very carefully & I see both disk, DISK 1 & DISK 2.... I think show it to a professial who know the Apple OS he will fix for you, your BIOS is working 100% perfectly, Just some software problem which I cannot figure out. Just show it to a person who know Apple OS & he will resolve your problem hereaffter.
                                        • ViLex
                                          • Dec 2022
                                          • 6
                                          • Russia
                                          #100
                                          I have an external SSD, it is divided into several disks, they have Maverick, High Sierra, Catalina, Big Sur OS installed on them. I understand how macOS works and unfortunately the internal disk is not visible. In the photo you see only the Kingston external drive and the OS loader
                                          • psdavid65
                                            Macbook Air A1466 820-3437-B Booting Problem
                                            by psdavid65
                                            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                            06-20-2024, 12:27 AM
                                          • echothegamer
                                            Macbook A1466 dies when charger disconnected
                                            by echothegamer
                                            Hello all,
                                            Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                            Details:
                                            Macbook 13' A1466
                                            Board (820-3209-A)
                                            Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                            Pictures below of Boardview and schematic...
                                            I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                            It's an older model and it is very likely that battery has become...
                                            10-28-2023, 12:00 PM
                                          • kenzo2
                                            Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                                            by kenzo2
                                            I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                                            I need dump file MACBOOK PRO A2159
                                            TSB4232(256)
                                            TSB4229(256)
                                            Thanks​
                                            01-11-2025, 04:18 AM
                                          • dbuergi
                                            Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                                            by dbuergi
                                            i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                                            Any ideas where to look?...
                                            11-07-2024, 10:57 AM
                                          • mon2
                                            A1466 Macbook Air (Liquid damage repair)
                                            by mon2
                                            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                            Macbook AIR Model A1466 Diagnostic 09-01-2021
                                            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                            Problems & Resolutions
                                            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                            09-01-2021, 09:31 AM
