HP i xxxxxxxx bios password,System Disabled, 8-digit code Unlock
Re: HP i xxxxxxxx bios password,System Disabled, 8-digit code Unlock
Master Password Generator for HP laptops [System Disabled]
After entering the wrong password for the third time, you will receive a
8 chars code from which the password can be calculated, e.g. [i 12345678]
Input: [i 19437206]
System Disabled: 19437206
Master Password: 24266649
Please note that the password is encoded for US QWERTY keyboard layouts.Last edited by SMDFlea; 08-13-2021, 01:23 PM.Comment
Input: i 73296388
System Disabled: 73296388
Master Password: 44807727
Every donation made will go towards server fees and maintenance costs.Comment
After having the need to crack an HP System Disabled code, I made up a little Master Password calculator that might be useful to some. It may not work in all cases, but it appears to work for most.
Here's a link to it:
https://docs.google.com/spreadsheets...it?usp=sharingComment
Channel: BIOS Requests ONLY!
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
- Loading...
CraterM
