Need bios LA-E811P
  • huzo
    • Sep 2014
    • 190
    • CROATIA
    #81
    Re: Need bios LA-E811P
    Hey guys, my friend did a win 10 upgrade today,and laptop restarted and doesn't work anymore...
    So he brought it to me, i tried flashing all the dumps that are here on the forum, like 10 of them..none work, all i get is fan spinning and white led turns on for a few seconds,then goes down and turns back up again...
    Is the KBC dead?I tried different ram,usb gets power for a few seconds too,but doesn't boot with win+b or win+v...i don't have original dump, i forgot to save it
    I measured the voltages, all are present except for GPU,maybe that comes later in the sequence,CPU gets 1.05V,ram 1.35V, 3.3V and 5V are present...
    the model is hp 15-bs038nm,board is LA-E811P.
    WTH is happening with HP and assistant?Why did it brick the laptop??
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #82
      Originally posted by huzo
      Hey guys...
      Since you don't have a backup and your BID is unknown, try the files uploaded in post #17 one after the other, one of them should "fit".
      Become a Badcaps supporter
      Thanks to all supporters.​
      • huzo
        • Sep 2014
        • 190
        • CROATIA
        #83
        You missed part of the text where i said i tried all of the dumps i found here on the forum
        I tried another bios chip too...i even tried stock bios from HP support,and got the same dumps as from post #17...
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          #84
          Is there any informations about your lap at back front !
          Did you try to flash bios and EC !
          • huzo
            • Sep 2014
            • 190
            • CROATIA
            #85
            ok, so friend actually was smart enough and saved the original bios, he forgot to mention it to me,i thought that after win update that happened, and he didn't mention that he actually tried to flash the bios via the ch341...but what he had told me is that he used ch341 without 1.8V adapter,and i don't know how did he manage to connect and read the dump... And to make the matter worse,he used a clip and sent 3.3V to 1.8V power line...
            i did measure the chip supply and it still has 1.8V on the motherboard, he fried the chip probably, but i used another chip and still didn't work..
            so here is the original dump after failed win 10 upgrade.
            @lapfix- i unfortunately don't have the EC programmer...they are to expensive for me...
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              #86
              Try this one , virgin no DMI
              Bios chip accepted :
              C22537 (Macronix MX25U64)
              EF6015 (Winbond W25Q16)
              EF6017 (Winbond W25Q64)
              C86017 (GigaDevice GD25Lx64)
              C86015 (GigaDevice GD25LQ16V)
              C22016 (Macronix MX25U16)
              EF4016 (Winbond W25Q32)
              EF3016 (Winbond W25X32)
              202016 (Micron M25P32)
              EF4017 (Winbond W25Q64)
              1F4800 (Atmel AT25DF641)
              1C3817 (EON EN25S64)
              20BB17 (Micron N25Q064)
              BID = 0832D
              • huzo
                • Sep 2014
                • 190
                • CROATIA
                #87
                i did try all of them already, but i will try 0832d later when i get home with new chip...the one i used for replacement is winbond 25Q64FWSIG and i do have 1.8V adapter...maybe this one is also faulty since it's from a donor board...
                but it's odd when i flash i always verify the chip and it says chip and memory are the same...i use neo programmer...so if the programmer says it's verified i trust it is...i could read from chip again and save what's in the chip and compare with dump programmed and see if there are any differences..
                • huzo
                  • Sep 2014
                  • 190
                  • CROATIA
                  #88
                  So i got to the cocnlusion that 3.3V went to the processor trough 10K ohm resistor array and something got fried...
                  I tried 3 different chips, it doesn't work, i started the laptop without the chip it acts the same, so it doesn't recognize the chip...
                  Data lines go directly from chip to the processors and the board became a donor...
                  • Macias
                    • Nov 2019
                    • 83
                    • Ecuador
                    #89
                    Re: Need ec bios LA-E811P Rev 2.0
                    Originally posted by peste
                    try..
                    It worked very well
                    :asentir:thank you
                    • mubopo
                      • Jun 2023
                      • Tanzania
                      #90
                      I would like to try the 0832D on the HP notebook 15 model 15-ra013nia but before I do, has anyone come across the original bios for this particular model?
                      Ran into issues when updating bios of the system released Apr. 2023. The system froze at 82% during the writing process, left it on all night, no change so I had to shutdown. A friend tried to use the Apr. 2023 release to extract the bin but no much luck there!
                      Any help received would be highly appreciated.
                      • peste
                        • Dec 2016
                        • 13915
                        • ROMANIA
                        #91
                        post the original bios of the laptop even if it is corrupted..
                        • canali
                          • Oct 2014
                          • 196
                          • turkey
                          #92
                          Thank you friends
                          • faisalhabib
                            • Apr 2017
                            • 29
                            • Bangladesh
                            #93
                            LA-E811P REV:2.0
                            100% OK TEST BIOS
                            FAST DISPLAY COME
                            • durango legrand
                              • May 2020
                              • 15
                              • benin
                              #94
                              Originally posted by classicandy
                              Re: HP 15 LA-E811P please bios
                              Non worked for me. I have Admin password lock. I have attached my bin file.
                              This works for me
                              thanks👌✌
                              • mazloum
                                • Sep 2012
                                • 504
                                • Lebanon
                                #95
                                Hello
                                I need this bios please:
                                HP bs-099nia
                                s/n= CND7244852
                                P/N= 2CJ91EA#BH5
                                BOARD: l50/csl52 la-e811p rev 1.0
                                the old bios is here
                                thanks in advanced ( note: the problem is 5 long caps with 3 short)
                                • peste
                                  • Dec 2016
                                  • 13915
                                  • ROMANIA
                                  #96
                                  Originally posted by mazloum
                                  Hello
                                  HP bs-099nia
                                  s/n= CND7244852
                                  P/N= 2CJ91EA#BH5
                                  you have everything you need at post #28...
                                  • pityulix
                                    • Nov 2021
                                    • 32
                                    • Targu-Mures
                                    #97
                                    Hi folks,HP laptop has 2 long and 2 short blinkings,meaning bios problem,thanks is advance for help.
                                    Model 15-ra060nq
                                    SN CND8497XMJ
                                    CSL50/CSL52 LA-E811P REV.2.0
                                    • peste
                                      • Dec 2016
                                      • 13915
                                      • ROMANIA
                                      #98
                                      Model 15-ra060nq
                                      SN CND8497XMJ
                                      you have everything you need at post #6...0832D
                                      https://www.badcaps.net/forum/troubl...-0#post3496291
                                      • skydive
                                        • Nov 2025
                                        • 4
                                        • Italia
                                        #99
                                        15-bs522nl
                                        ProdID: 3FX00EA#ABZ
                                        SN: CND8125C06
                                        Motherboard: CSL50/CSL52 LA-E811P
                                        I attach the original bios extracted from the chip.
                                        Thank you.
                                          SMDFlea commented
                                          Editing a comment
                                          Thread merged with LA-E811P topic.
                                      • peste
                                        • Dec 2016
                                        • 13915
                                        • ROMANIA
                                        #100
                                        Originally posted by skydive
                                        15-bs522nl
                                        ProdID: 3FX00EA#ABZ
                                        SN: CND8125C06
                                        Thank you.
                                        read the post above
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • maanee11
                                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                          by maanee11
                                          Hello Everyone,
                                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                          In the website, you can only see specs etc.
                                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                          11-08-2025, 04:08 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
