Microsoft Surface Pro 3 UEFI password
Hello. I don't really understand what program I need to download to read the bios from the surface. I downloaded Intel ME System Tools v5 but it opens on Windows. I don't have a system installed on the surface and booting is only enabled from the SSD drive and that's the problem because how do I enter the command line on it? Can I do it by connecting it to the computer? Do I have to do it on it. If it's this program, if I transfer it to a pendrive, will I be able to run it somehow from the command line to make a bios backup. It is actually as an exe. Alternatively, can I ask for an attachment with this program? Here is the surface version:
Surface Pro 3
System UIDD 13F13543-8B09-6DC4-AF8BF63A1161
SN 056930544753
Asset tag 0
Version 2.16.1243. Copyraught 2013 American Megatrends, Inc.
I managed to connect the drive via USB from Windows, it started and I'm trying to do it from Windows but I have these errors. I'm trying on different versions of fptw and I get different errorsHello. I don't really understand what program I need to download to read the bios from the surface. I downloaded Intel ME System Tools v5 but it opens on Windows. I don't have a system installed on the surface and booting is only enabled from the SSD drive and that's the problem because how do I enter the command line on it? Can I do it by connecting it to the computer? Do I have to do it on it. If it's this program, if I transfer it to a pendrive, will I be able to run it somehow from the command line to make a bios backup. It is actually as an exe. Alternatively, can I ask for an attachment with this program? Here is the surface version:
Surface Pro 3
SN 056930544753
Asset tag 0
error during PMX call error 1275 error 51 or 284 fail to load driver pci access for windowsComment
Upload your dump file.I managed to connect the drive via USB from Windows, it started and I'm trying to do it from Windows but I have these errors. I'm trying on different versions of fptw and I get different errors
on version v9.5 r6 it shows that I do not have administrator rights and cmd is enabled with administrator rights and that it cannot load pci drivers for access in windows. I suppose that this may be due to the fact that the system is started from usb. However, when opening the installation from a pendrive I cannot install it because the partition cannot be set, an error is displayed and the shortcut alt + r does not work, I can only enter repair mode and there in cmd but there is a boot partition X and when I want to switch to the pendrive the command cd C:/ returns to X: again and I do not know how to bypass this, I am out of ideas. I do not want to unglue it because the screens in them are such that 80% crack when ungluing.Comment
Can someone assist me with the password for the following:
Surface Pro 3 64GB
S/N: 034839143453Attached FilesComment
try....
2i2m9c5
Every donation made will go towards server fees and maintenance costs.Comment
I put the folder that contains the fptw64.exe directly in C: drive. From there, type cmd in your taskbar search and right click "Run as administrator".on version v9.5 r6 it shows that I do not have administrator rights and cmd is enabled with administrator rights and that it cannot load pci drivers for access in windows. I suppose that this may be due to the fact that the system is started from usb. However, when opening the installation from a pendrive I cannot install it because the partition cannot be set, an error is displayed and the shortcut alt + r does not work, I can only enter repair mode and there in cmd but there is a boot partition X and when I want to switch to the pendrive the command cd C:/ returns to X: again and I do not know how to bypass this, I am out of ideas. I do not want to unglue it because the screens in them are such that 80% crack when ungluing.
Then type cd c:/foldername to switch to that folder (replace foldername with the name of your folder; simplify it if it's too long to type)
then run the command to dump:
fptw64.exe -BIOS -D yourbackupname.bin
(yourbackupname being whatever you want the dumped bin to be called; name it something easy and you will find it in said folder)
Also, I did mine on a fresh clean install of the official SP3 Windows 10 recovery image. If you cannot afford to lose your current OS and it doesn't work, consider perhaps creating a temporary partition in which you can perhaps install a clean copy of the stock Windows 10 image.Comment
I would be very grateful for bios password for:
Surface Pro 3 256GB
SN: 006607243353
https://www.badcaps.net/donateComment
Please post your request along with the laptop serial number in the Surface Pro 6 topic -> https://www.badcaps.net/forum/troubl...pro-6-passwordComment
Surface Laptop 3 512GB
SN: 047126101557
Thank you.Comment
Please help retrieving the password
surface pro 3
SN: 059792362053
256 GBAttached FilesComment
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 08:10 PM
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 08:10 PM
- Loading...
