Yepo 737in
  • peste
    • 12610
    • ROMANIA
    Yepo 737in
    Hi .. I need bios for In-SA116H_V01 motherboard,or someone to fix this ...
    thank you...
  • peste
    • 12610
    • ROMANIA
    Re: Yepo 737in
    I found bios from the YEPO 737 laptop, but I don't know what the motherboard. The laptop doesn't work with any ...starts and after a few seconds, the cooler spins to the maximum, has no video .. I tried to make a good bios but I failed ...
    • eikspaj
      N1NJ4W4RR10R
      • Mar 2015
      • 135
      • Philippines
      Re: Yepo 737in
      i hope this will help you
      goodluck
      There are 10 types of people in the world. Those that understand binary and those that don't.
      • peste
        • 12610
        • ROMANIA
        Re: Yepo 737in
        not work, starts but has no video ..
          • 20659
          Re: Yepo 737in
          Are you sure about the model number 737in ?
          • eikspaj
            N1NJ4W4RR10R
            • Mar 2015
            • 135
            • Philippines
            Re: Yepo 737in
            i think he mean 737i...
            the popular one is 737a, same as my backup
            • peste
              • 12610
              • ROMANIA
              Re: Yepo 737in
              He writes in Chinese, so he translated the application from my phone, but what he writes on the motherboard is ok.
              • peste
                • 12610
                • ROMANIA
                Re: Yepo 737in
                motherboard.
                  • 20659
                  Re: Yepo 737in
                  Your bios backup isn`t easy to fix,its corrupt
                  • peste
                    • 12610
                    • ROMANIA
                    Re: Yepo 737in
                    yes i know..and that's why i posted several bios found, maybe someone can make a good bios ..I tried to make a good bios but I failed ...
                      • 20659
                      Re: Yepo 737in
                      Try these 2 bios .
                      • peste
                        • 12610
                        • ROMANIA
                        Re: Yepo 737in
                        Fixed bios1 works ... this message appears at the beginning, but, I think I can handle it from here.
                        Thank you SMDFlea..
                          • 20659
                          Re: Yepo 737in
                          You`re welcome .
                          • Alax-2
                            • May 2020
                            • 8
                            • Россия
                            Re: Yepo 737in
                            Originally posted by peste
                            fixed bios1 works ... This message appears at the beginning, but, i think i can handle it from here.
                            Thank you smdflea..
                            Hello! I have the same sa116h_v01 board. After changes in the BIOS, when you boot the computer requires you to enter a password. You wrote above that you changed BIOS. But there are two flash MSs.gd25q80csig and gd25lb64cvig. Which one to flash? And How? Or without soldering MS, via usb? Sorry for the stupidity, I work as an industrial electronics engineer and system. board for me as part of a CNC machine.
                            https://translate.yandex.com/translator/Russian-English
                              • 20659
                              Re: Yepo 737in
                              Desolder and post your bios backup for gd25lb64cvig
                              • Alax-2
                                • May 2020
                                • 8
                                • Россия
                                Re: Yepo 737in
                                Спасибо! Можно взять FIX1.zip, который Вы опубликовали выше?
                                Thank! Can I take the FIX1.zip that you published above?
                                  • 20659
                                  Re: Yepo 737in
                                  You can try it,but make a backup of your bios first. The pass in your bios can be removed if you backup and post it. You`ll need an SPI bios programmer with 1.8V adapter,and a clip if you can`t desolder the chip. https://www.aliexpress.com/item/4001045543107.html
                                  • Alax-2
                                    • May 2020
                                    • 8
                                    • Россия
                                    Re: Yepo 737in
                                    Спасибо, SMDFlea! Уже заказал CH341A.
                                    Thank SMDFlea Already ordered CH341A
                                    • Alax-2
                                      • May 2020
                                      • 8
                                      • Россия
                                      Re: Yepo 737in
                                      Unfortunately, dumps from the Fix1 and Fix2 archives did not fit. When loading, the screen is black, there is no video. When I flash the backup, it asks for the password again. Archive dumps had to be recorded with a new name? Or do you need to deal with another gd25q80csig chip?
                                        • 20659
                                        Re: Yepo 737in
                                        Post both your original bios backups here !
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • Bloodhoundje
                                          by Bloodhoundje
                                          03-16-2024, 03:12 PM
