hp 625 Working dump
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    hp 625 Working dump
    Working dump.
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    Re: hp 625 Working dump
    work fine thnx
    OKBALORD
    • baddjavo
      • Jun 2018
      • 88
      • Serbia
      Working. Tnx.
      • FedorovV
        MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
        by FedorovV
        MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
        Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
        The cooling system is cleaned, the contact spot is good.
        I need a working dump from laptop to check.
        This is an original, not working dump....
        03-10-2024, 07:26 PM
      • ronaldopdias
        A3113 corrosion to LAS = No keyboard, yet screen and trackpad work fine
        by ronaldopdias
        Hi All.
        I have a A3113 MacBook Air 13" (M3) that had minor liquid damage. The screen remains on if the lid is closed, the keyboard doesn't work, but trackpad and Touch ID does.​
        The LAS was corroded, but I have tested it on an A2681 (M2) and it functions fine. Anyway, I ordered a new one and replaced it and calibrated it with Apple.
        I have checked the main voltages going to the daughterboard and they are present. Diode mode reading on the LAS line which goes direct to the SoC is also correct, no short.
        So then I replaced the daughterboard, and...
        06-16-2025, 03:12 AM
      • cyber16
        Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
        by cyber16
        Please I need help.
        Quick rundown long story shorter, but still long winded.
        I received this Lenovo P1 GEN 1 about a year ago from a business.
        It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
        At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
        Then late last fall my father-in-law suffered...
        09-08-2022, 07:32 AM
      • Lcd22
        Lenovo s145-15api work fine after bios flash for some time, like a few restarts or power cycles.
        by Lcd22
        Hi! I have a Lenovo s145-15api Ryzen 5 3500u, he need a bios reflash, i made that (tried with ch341a and ezp2023+). I tried a lot of dumps, and all do the same, so i think is a hardware problem. So after reflash, laptop work fine a short time, after some restart or power on/off, the laptop have again same symptoms, need a new bios. Do it again and again and same result. What are u think is the problem?
        08-28-2024, 10:38 AM
      • Björn Brunkau
        Palit 980ti no FBVDDQ, no NVVDD, all other voltages working fine
        by Björn Brunkau
        Hi there,
        I am looking for help with my broken 980ti. Had a bad DrMos (the bottom one) and replaced it, card worked for a short moment, but I got another shortes DrMos (second one) and replaced that one aswell.
        Now I don't measure any shorts, I have 12v, PEX, 5v, 3.3v all working fine (probing points on card), but I can't get any voltage at FBVDDQ or NVVDD probing points.
        Where could I check to find the fault?
        You think my first DrMos could be bad, because I read that the first one will activate core?
        Don't want to replace that one when I can just test other...
        05-11-2024, 10:41 AM
