Needed Bios Dell Precision 5530 password
This topic is closed.
    Re: Needed Bios Dell Precision 5530 password
    Originally posted by FjordFisch View Post
    Thank you very much for your great support. The unlocked BIOS worked perfectly.
    Just a remark: I used the NeoProgrammer 2.2.0.10. In the first attempt after flashing the new BIOS the passwords were still in there, and the compare function showed differences. NeoProgrammer likely skips all 0xff areas in the buffer to reduce programming time, so it doesn´t overwrite the password areas. I had to clear the flash memory before programming. After this the compare function showed no differences to the buffer anymore.
    using CH341A and compatible software you have to erase 1st bios chipset then write it with .bin file. Or check box "auto-erase" in settings.
      Hi, good, I have a 5330 with adsolute enabled and it cannot be disabled, how would I do it? I leave my bios dump
        yours is Latitude 5330, not Precision, post your request to proper thread.
          You MUST:
            Thread closed
