HP EliteBook 2570P have bios password
  • dimah77
    • Sep 2016
    • 147
    • ALGERIA
    Hi ,
    Having Problem with programming HP EliteBook 2570P Bios DUMP
    I try many dump files but no success, only the original BIN backup can be written, here is :
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Hp 2570p bios password
    Originally posted by dimah77
    Hi ,
    Try this
    • dimah77
      • Sep 2016
      • 147
      • ALGERIA
      Problem in MX25L12845E 16 pins , replaced with 25Q128FV 8 Pins
      PASS REMOVED AND PROBLEM SOLVED
      Thanx IMRANROMI
      • morrisx
        • May 2016
        • 8
        • hk
        HP EliteBook 2570P have bios admin password, how to unlock the admin password? thanks.
        BIOS Version: 68ISB Ver. F.44
        The attached file is my bios backup.
        • morrisx
          • May 2016
          • 8
          • hk
          Re: HP EliteBook 2570P have bios password
          How to remove or reset bios admin password for hp2570P? thanks!
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            I think you not read bios chip right?Read bios chip have 16pin.Send here complete bios i will unlock
            • morrisx
              • May 2016
              • 8
              • hk
              Thanks imranromi
              Btw, I haven't no any this experience before.
              How to Read bios chip have 16pin?
              Is it use the method as below from youtue?
              -> https://www.youtube.com/watch?v=vgbWtxv_hqM
              Many thanks.
              • morrisx
                • May 2016
                • 8
                • hk
                And, is it possible update my BIOS.bin from someone's backup to fix the issue?
                • morrisx
                  • May 2016
                  • 8
                  • hk
                  would you please provide the procedure how to do it, thanks.
                  • morrisx
                    • May 2016
                    • 8
                    • hk
                    Please help!!!
                    • imranromi
                      • Jan 2015
                      • 1288
                      • Pakistan
                      Use heat gun remove ic 16pin Ic put in bios programmer read and save
                      • Aditya11ttt
                        Adi
                        • Feb 2019
                        • 180
                        • India
                        Is it solved or still pending?
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          I think is not solve you download file then you know what wrong.
                          • morrisx
                            • May 2016
                            • 8
                            • hk
                            • morrisx
                              • May 2016
                              • 8
                              • hk
                              Thanks imranromi! Oh, I see -> Use heat gun remove ic 16pin Ic put in bios programmer read and save
                              • imranromi
                                • Jan 2015
                                • 1288
                                • Pakistan
                                If you dont have Heat gun or other tool then you need SMC.bin file.But this file is not free.
                                • Kamvret
                                  • Nov 2019
                                  • 6
                                  • Indonesia
                                  try this!
                                  https://ghostlyhaks.com/blog/hacking...book-elitebook
                                  • Kamvret
                                    • Nov 2019
                                    • 6
                                    • Indonesia
                                    Hi ,
                                    try this method
                                    • guebaili
                                      • Nov 2019
                                      • algeria
                                      i have this model of bios and i dont know the password 68ISB Ver. F.44 PLZ help
                                      • Kamvret
                                        • Nov 2019
                                        • 6
                                        • Indonesia
                                        have you solve your problem?
                                        send me your original bios backup, i'll try to help you
                                        • Buzzfuzz2k
                                          Bios password removal on a Unowhy dump
                                          by Buzzfuzz2k
                                          Hi Everyone,
                                          I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                          The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                          the Computer is a Unowhy small pc
                                          N° UYM6524702229
                                          After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                          My first attempt was to get the bios dump from windows...
                                          11-13-2023, 07:37 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
