Dump bios Asus X507U
  • peste
    • 13678
    • ROMANIA
    Originally posted by Glat
    Добрый день всем . Есть Asus X507UAR S/N: J9N0CV03K05437A. BIOS запаролен, Помогите снять пароль ,
    Good day to all. I have an Asus X507UAR S/N: J9N0CV03K05437A. The BIOS is password protected. Help me remove the password.
    In English please...
    post the original contents of the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    • Glat
      • May 2018
      • 15
      • Israel
      how do i upload a file,???
      • Glat
        • May 2018
        • 15
        • Israel
        Thiese is original BIOS With password.
        • Bios Cracker
          • Oct 2024
          • 322
          • India
          Provide complete details pls.
          model number and service tag/serial number
          • Glat
            • May 2018
            • 15
            • Israel
            • hoaca388
              Badcaps
              • Jan 2022
              • 12354
              #26
              Are you kidding us ?
              • Bios Cracker
                • Oct 2024
                • 322
                • India
                #27
                Try and update
                Admin Password : eshli1211
                - Boot Password : eshli1211​
                • Glat
                  • May 2018
                  • 15
                  • Israel
                  #28
                  thank you very much
                  • x1rey gt
                    • Jan 2024
                    • INDONESIA
                    #29
                    thank you so much, this bios work
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
