HP elitebook 820 g3
  • Sparo
    Quicksilver
    • Jan 2022
    • 4554
    • M\A
    • Anime, Edge Computing, Football, Snooker
    #161
    Originally posted by hasanaga_84
    hp 820 g3 serial number:5cg6161gwd The device starts up but there's no display. I suspect it's the BIOS. Can you help me? Thank you.
    Hi, try writing only the 16MB chip. Good luck!
    HP EliteBook 820 G3 Base Model Notebook PC
    System BIOS (N75) Version: 01.55 Rev.A
    Enjoying our forum? Subscribe to unlock extra perks!
    >> Upgrade here <<
  • Sparo
    Quicksilver
    • Jan 2022
    • 4554
    • M\A
    #162
    hasanaga_84
    Unfortunately, the problem persists, master.
    Try again, I've updated the file. If it still doesn't work, then try flashing both of these files
    System BIOS + ECBIOS (N75) Version: 01.24 Rev.A​
    >> Upgrade here <<
    • GERATKD
      • Jun 2026
      • México
      #163
      Hello, I have a major problem with this laptop that I’d like your help solving. As you know, this laptop uses a WSON8 BIOS chip, which means it’s practically mandatory to desolder it to read it properly with a CH341A controller adapter, but in a desperate attempt to make things easier in a “miraculous” way, the computer read it using the SOIC8 tweezers. However, I assumed that connection was stable when it wasn’t, and I ran the erase process to rewrite the BIOS. To some extent, it was working, I even saved a backup but it wasn’t complete the clamps simply didn’t make a firm enough contact for the processes to run correctly. So I ended up without the original BIOS for that laptop, and on top of that, I was getting errors. That’s when I finally desoldered the chip and used a socket I bought on AliExpress, which was clearly the right approach because the chip read it without any issues on the first try and everything worked fine. But the problem is that now I don’t have a BIOS, and none of the BIOS files I’ve downloaded from the internet for this model work for me, the laptop simply won’t boot, it stays on all the time without displaying image and the fan runs at full speed. I even performed a “ME” clear using FIT and extracted the repositories specifically for version 11.8.50.3470, but nothing changed, it’s still doing the same thing. Could you help me find a solution? Thanks
    • GERATKD
      • Jun 2026
      • México
      #164
      Motherboard:
      HSTNN-I42C
      6050A2892301 -MB-A01
      SN: 5CG8272KD0
      ProdID: Z7Y18LA
      • Sparo
        Quicksilver
        • Jan 2022
        • 4554
        • M\A
        #165
        Originally posted by GERATKD
        Motherboard:
        HSTNN-I42C
        SN: 5CG8272KD0
        ProdID: Z7Y18LA
        Hi, you can try the files from the post above yours
        These ones > (System BIOS + ECBIOS (N75) Version: 01.24 Rev.A)
        >> Upgrade here <<
        • nafienew
          • Aug 2014
          • 177
          • up
          #166
          hp elitebook 820 g3
          sn 5cg91336z1
          6050a2892301-mb-a01
          The RAM keeps beeping even after changing the RAM; The circuit itself is fine. I tried the BIOS files mentioned above, but it didn't work. I hope the original BIOS file for the device can be repaired.
          • Wutru
            HP Elitebook 820 G4 BIOS repair assistance required
            by Wutru
            Hi guys,
            If someone would be able to provide some expertise, I'd be very grateful.
            BIOS Corruption - Cause
            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
            09-06-2025, 10:32 AM
          • STKR123
            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
            by STKR123
            Greetings badcaps community,
            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
            I learned that desoldering...
            10-29-2024, 06:03 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • wrinex
            bios request/fixing dump HP elitebook 840 G6
            by wrinex
            Hi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
            i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...
            04-09-2026, 12:39 PM
          • Trademark
            Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
            by Trademark
            I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
            This is NOT a BIOS password removal request.
            I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
            Laptop Information
            • Model: Acer Predator Triton 16 PT16-51-99GL
            • Motherboard: DA0ZQDMB8AE Rev. E
            • Main SPI flash: Winbond W25Q256JVEN (32MB)
            • Secondary
            07-22-2026, 08:57 AM
