HP elitebook 820 g3
    Re: hp elitebook 820 g3 bios
    ok ghamidi i try tanks
      doesn't work same problem
        Originally posted by nassih View Post
        hello i need clean me bios for this plz
        the laptop work with orginal bin file ???
          its work without display
            Try this file
              tanks ghamidi i will try it after tomorrow and tell you
                doesn't work same problem,strange bios
                  thank you for your support i just damaged the bios chip, maybe i have set my hot air station to a slightly high temperature,now i need to find a new one, i will keep you posted
                    Re: HP elitebook 820 g3
                    6050a2725001-mb-a01
                    already tried alot of versions here (not working), dumping original roms and cleared one, machine drawing 0.5 a, vcore rails present. there was corrosion under ram, cleaned it and resoldered, should be fine (tested with tester).
                    thanks for any tips
                      6050A2725001-MB-A01 bios
                      hello i need help for fix this bios
                      laptop on but no data
                        Re: 6050A2725001-MB-A01 bios
                        HP EliteBook 820 G3 Notebook PC
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          you fix old bios
                            you fix old bios
                            Yes !
                              Re: HP Elitebook 820 G3
                              PESTE = life savior :-) I messed up my bios read and his outimage saved my laptop - after flash all was restored and it is working again! Big thx
                                Hp 820 G3 corrupted bios
                                Hi I have 3 laptops and all 3 go mad the fan is spining high and the pcs get warm. i suspect a virus on my bios as I replace hard drives and fresh install of windows 10 and got same problem. Could you please look at this bios and clean it if necessary. I need a good clean bios file
                                Many thanks for all.
                                PS: I don't need password remove as there is no password
                                  Re: Hp 820 G3 corrupted bios
                                  Here's your Clean file, hope it works fine.
                                  all donations are welcome,
                                    Hi Thanks, but i don't need just a clean me bios from my bios file as I suspect that this one is infected by a virus, so I need an other good working clean bios.
                                    Many thanks
                                      Many thanks
                                      Here's your new file, try it and give me the results.
                                      Your old file has been fixed using the image that's provided by HP.
                                        Hi many thanks, I will test this today and repport.
                                        Thks again
                                          Hi not tested yet due bocken bios chip when triying to unsold it from the motherboard. I m waiting for new one to come and I will report, many thanks again.
                                          I have an other question about the way you did torebuild the bios from hp bios download?
