Can someone fix this original bios please Asus x55a REV 2.1
Asus x55a bios to be fix
Tags: None
Re: Asus x55a bios to be fix
already fix i flashed the bios with this https://www.badcaps.net/forum/showth...light=x55a+revComment
update:still have issue it shuts off after 30minutes can someone clean the me region of my original dump pleaseComment
Here you go .Attached FilesComment
i tried smdflea bios clean it still shutdown after 30mins. because before this is pentium i upgraded to i3 2nd gen should i bring back to pentium?Comment
its working i put it back the pentium processor and now it been 2hours no shutdown, thanks again smdflea and alaborbeComment
ASUS X55A REV:2.2 bios help
halOoh guys, good day... ^_~
anyone who got a working bios for this
ASUS X55A REV:2.2
or help me clean this bios...
tnx.....^_~Attached FilesComment
Re: ASUS X55A REV:2.2 bios help
ENJOY NEW MODDED BIOS WITH CLEAN ME
tnx for the reply qayyum... i will try this file.. i will update u later...^_~Comment
Re: Asus x55a REV 2.2 bios help
post your bios backupComment
I put bios from the forum. My flash was brokenAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Asus x55a rev 2.1
hi guys, here again looking for this bios
any1 plz?
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by maciek1221Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
Config:
Model: Asus G512LV-HN235T
Platforma: G532LWS rev. 1.3
CPU: intel i7-10870H
GPU: nVidia Geforce RTX2060/...-
by TechnodocAsus laptop G614JZ-N3012W Rog Strix with i7
Mainboard G634J-PMV-VGT
6050A3441302-MB-A01
2023-02-10
Power button works okay....power light goes on
Red "bottom" leds go on
Charging led works
Fans do not spin, capslock key does nothing, screen stays black
I would like to program the bios again, to rule out a corrupted bios.
However I run into a size error
The bios chip is a Winbond 25R256JVEN
Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...-
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
- Loading...
