DA0Z09MBAH0 REV: H bios need
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Hi, regards
    DA0Z09MBAH0 REV: H bios need 2 Mb kbc.
    My backups kbc dump
    • 20453
    Re: DA0Z09MBAH0 REV: H bios need
    Your bios is 2 and 4 MB ,total 6MB bios split across 2 SPI chips.Flash both of these.
    • husniddin
      • Jan 2017
      • 98
      • Uzbekistan
      SMDFlea, Thanks dumps is working
      • juanchaco
        • Jan 2019
        • colombia
        mine is 8 megabytes the bios and the ec of 128k
          • 20453
          Post the full laptop model number,serial and bios + EC backup
          • aliumar2183@gmail.com
            • Jun 2023
            • 5
            • Pakistan
            i need dA0w03mbah0 rev h bios required
              • 20453
              https://www.badcaps.net/forum/troubl...12#post1769012
              RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
              https://www.badcaps.net/forum/troubl...ore-posting​
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
