Firmware of Lg TV 26le5300 required
  • Chaks
    • Sep 2015
    • 115
    • India
    Cannot find the Firmware for the LG TV 26le5300. If anybody has it would it be possible to upload it here as I want to reflash my TV.
  • jovani1989
    HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
    by jovani1989
    HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...
    06-11-2025, 01:54 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • mangcom
    ASUS G513IE 6050A3249301-MB-A04 IT5571E-128 EC firmware is required.
    by mangcom
    저는 한국인이라 영어가 잘 안 될 수 있습니다. 양해 부탁드립니다.
    EC가 손상되어 교체했는데, 펌웨어가 없어서 제대로 작동하지 않습니다.
    ASUS G513IE 6050A3249301-MB-A03의 펌웨어도 작동하지 않습니다.
    혹시 해당 펌웨어를 가지고 계신 분이 계시면 도와주시면 감사하겠습니다.
    미리 감사드립니다....
    05-22-2025, 10:46 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
