Asus GL552VW Bios dump
  • harrysland79
    • Nov 2018
    • Poland
    HI
    I need bios to asus rog GL552vx from working laptop saved by AFUDOS - 6 MB SIZE
    PLEASE HELP
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • kodox
    Asus ExpertBook B1400CB Bios Dump Needed
    by kodox
    need original bios dump, original bios has flashed by other technician before me.
    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
    unit info:
    Model: Asus ExpertBook B1400CBA-0711A1235U
    S/N: R6NXNZ006657238
    CN: 7F6F
    Mainboard Code: B1500CBA R2.1...
    08-16-2025, 12:20 PM
