pls Bios HP Probook 450 G5
  • macl
    • Aug 2022
    Re: pls Bios HP Probook 450 G5
    450G5
    Please, Ideas or suggestions on that? Any kind of help is appreciated.
    • peste
      • 14410
      • ROMANIA
      #202
      Originally posted by macl
      450G5
      What problem do you have???..
      • macl
        • Aug 2022
        I bought a used Laptop. Unfortunately BIOS setup is secured by password, but I need to enable Virtualization Technology (VTx) & Virtualization Technology for Directed I/O (VTd) on my Laptop.
        Automatic BIOS Update Setting are disabled
        Update BIOS via Network is enabled (but needs still pw)
        Legacy Support is disabled and Secure Boot is enable (suckz also)
        I've no idea how to change BIOS settings without the Admin password. Also I can't boot any native cracker software (tools included in Hirens or Kali for eexample), because secure boot Option.
        So I'm looking for a possibility to flash BIOS without extracting the Chip from Board, because I don't have the hardware ans the knowledge to flash the EEPROM and I'm also not good in disassembling and assembling microelectronics, but didn't found any alternative solution till now.
        Maybe u've an idea?
        • peste
          • 14410
          • ROMANIA
          #204
          Maybe u've an idea?
          you have to remove the chip from the board and read it, otherwise you can't..
          • Mazorca
            • Jan 2017
            • 463
            Get yourself a cheap Ch341a programmer, less than US10, with clip preferably. program it with asprogrammer. Take out the CMOS battery if it has one. Identify your BIOS Chip, usually it reads Windbond or MX and has lettering like W25Q128FV. Read and save first reading, close programmer and start again, do a second read and save. Again close program, unhook everything and start again, do the third read and save. Download WINHEX, a hex editor, and compare your saved readings, two at a time. They should all be identical, otherwise, do some more readings and pray to the internet gods you got it all right. Remember that is your backup in case something goes bad. Rar or Zip the bin file you got and post it here, someone will help you.
            I myself rely on the TL866II medium priced, and a 200mm adapter for legged chips and a double WSON adapter, 8X6 and 6X4 for legless chips.
            • haris199000
              • Nov 2019
              • 73
              • pakistan
              #206
              please clear this bios SERVICE TAG 5CD8323C8Z
              • hardware1
                • Sep 2021
                • 2953
                • N/A
                #207
                Your file now is Configured. try it.
                all donations are welcome,
                • arisskarp
                  • Nov 2021
                  • 15
                  • greece
                  #208
                  Can please someone unlock this bios (see attached file) for hp probook 450 G5
                  Thanks in advance
                  • hardware1
                    • Sep 2021
                    • 2953
                    • N/A
                    #209
                    Thanks in advance
                    Here's your unlocked file, try it.
                    • arisskarp
                      • Nov 2021
                      • 15
                      • greece
                      #210
                      bad
                      • Atiq
                        • Dec 2017
                        • 78
                        • India
                        #211
                        I am uploading my old bios, its not powering.
                        i tried the above bios but very late display it takes 2mins for the display to come.
                        can someone help me to fix my bios please. thanks
                        • hardware1
                          • Sep 2021
                          • 2953
                          • N/A
                          #212
                          Here's your new bios file, try it and let me know the results.
                          • Atiq
                            • Dec 2017
                            • 78
                            • India
                            #213
                            hardware1:
                            Thank you very much it's working good
                            • mnciks11
                              • Aug 2019
                              • 347
                              • south Africa
                              #214
                              Hello guys,i need help with my bios, laptop turning on, fan spinning fast and no display
                              below its my original file
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12645
                                #215
                                HP ProBook 450 G5 Notebook PC
                                • nikola07
                                  • Sep 2018
                                  • 36
                                  • Ukraina
                                  #216
                                  good afternoon. please help me fix my bios. black screen. the fan is working at maximum. thanks
                                  • hardware1
                                    • Sep 2021
                                    • 2953
                                    • N/A
                                    #217
                                    Here's your New Bios, try it and give me the results.
                                    Serial Number: 5CD7440LF1.
                                    • mactouch
                                      • Nov 2018
                                      • 101
                                      • Abu Dhabi
                                      #218
                                      could any one please help me to me region this bios file
                                        • 22772
                                        Have you tried it yourself,there are some guides you can follow
                                        How to clean ME/TXE region
                                        https://www.badcaps.net/forum/showpo...41&postcount=3
                                        Badcaps relies on your donations to pay for hosting ( Currently AWS is $8000 alone) site advertising goes nowhere near to covering these costs. To keep everything that you and i rely on for free,Please consider donating, thank you.
                                        • nikola07
                                          • Sep 2018
                                          • 36
                                          • Ukraina
                                          #220
                                          everything does not work, the same capslook flashes 6 times
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
