Compaq mini cq10 bios
  • Pascal Komlassan
    • Jan 2017
    • 808
    • TOGO
    hello please i need the bios dump of this hp 6050A2326001-MB-A02 bios
    • 22288
    Re: Compaq mini cq10 bios
    Whats the model number e.g. CQ10-130SE,CQ10-500EO,CQ10-101SA,CQ10-688nr,CQ10-400SA .
    You can get the bios from hp ,and extract it using the right software. Why don`t you try and learn how to do it .
    • imranromi
      • Jan 2015
      • 1292
      • Pakistan
      Try this today i try working well.
      • Pascal Komlassan
        • Jan 2017
        • 808
        • TOGO
        Originally posted by smdflea
        whats the model number e.g. Cq10-130se,cq10-500eo,cq10-101sa,cq10-688nr,cq10-400sa .
        cq10-130sf
        • Pascal Komlassan
          • Jan 2017
          • 808
          • TOGO
          Originally posted by imranromi
          try this today i try working well.
          thanks bro it work
          • xupremex
            • Aug 2019
            • Saltillo
            Thanks for the input.
            • Ibherath
              • May 2020
              • 16
              • Sri lanka
              thank you.it worked
              • robante15
                • Nov 2020
                • 64
                • El Salvador
                Thanks, this BIOS work on an Compaq CQ10-120LA
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
                • Svyatpro
                  Alienware X17 R2 (LA-L613P) need BIOS dump or BIOS extract
                  by Svyatpro
                  Hello folks.
                  I have Alienware X17 R2 (LA-L613P) with broken BIOS after unsuccessful BIOS update.
                  Dell_PFS_Extract cannot extract BIOS from bios update.
                  Here is my dump....
                  03-17-2024, 12:41 PM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
