need bios dump asus -x541s-
  • okbalord
    • Jun 2017
    • 205
    • Algeria
    hi; need bios dump asus -x541s- x541sc main board rev 2.0
    thank u
    OKBALORD
  • arfiqri93
    • Feb 2019
    • 7
    • malaysia
    Re: need bios dump asus -x541s-
    me too, looking for bios bin for x541s
    • max7
      • Nov 2015
      • 69
      • sudan
      Laptop Model Asus X451MA-VX299H
      Motherboard X451MA MAIN BOARD REV. 2.1
      KBC / EC ITE IT8985E
      Flash WINBOND 25Q64FW (U2801) 1.8V
      Size (files zip)
      File type Dump – bin – rom – bios
      • okbalord
        • Jun 2017
        • 205
        • Algeria
        Ty but not working
        OKBALORD
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          post your original dump
          • okbalord
            • Jun 2017
            • 205
            • Algeria
            OK X541SA MAIN BOARD REV; 2.0
            thx
            this bios is good and he work fine
            OKBALORD
            • okbalord
              • Jun 2017
              • 205
              • Algeria
              ty bro but the bios is good i just reflash it with the old bios and the labtop was fine and work a gain
              thx
              OKBALORD
              • ezzeddin
                • Feb 2019
                • 16
                • syria
                hello i have problem with this laptop i wannt reprogram io cause its locked with password
                i have rt809h programmer how can i connect it with io (kb902fq)
                i need pins with the way mainboard x541sa re 2.0
                • kalisko
                  • May 2016
                  • 45
                  • Serbia
                  thank u
                  Good 100%, original read from the board !!!
                  • Areos
                    • Jun 2020
                    • 36
                    • México
                    Thank you!! I need this a lot.
                    • Areos
                      • Jun 2020
                      • 36
                      • México
                      thx
                      So this is a Working Bios for the Asus X541S right??
                      • Areos
                        • Jun 2020
                        • 36
                        • México
                        thx
                        I confirm this is a Working bios for the Asus X541SA Rev 2.0, thank you!!
                        • KoAungThaw
                          • May 2020
                          • 5
                          • Myanmar
                          100% working.
                          I'm already testing for my Laptop Asus X541SC rev2.0
                          • Maung gyi
                            • Sep 2017
                            • 3
                            • Myanmar
                            X451sc rev2.0
                            ec bios dump have?
                            Ene kb902
                            • peste
                              • Dec 2016
                              • 13847
                              • ROMANIA
                              Originally posted by Maung gyi
                              X451sc rev2.0
                              ec bios dump have?
                              Ene kb902
                              Ec bios for X541SC..
                              • fyaagoub
                                • Dec 2016
                                • 269
                                • maroc
                                • Mike weissman
                                  • Nov 2022
                                  • 4
                                  • Algerie
                                  thnks
                                  • canali
                                    • Oct 2014
                                    • 195
                                    • turkey
                                    • Moalia
                                      • Aug 2019
                                      • 8
                                      • iran
                                      100% working.
                                      thank you very much​
                                      • mkdj
                                        by mkdj
                                        Dear all,
                                        10-19-2025, 04:41 AM
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
