Dell Latitude 5580 (LA-E091P)
  • LBTT1121
    replied
    Originally posted by hamadasaad View Post
    Hello, please help me
    I have a Dell Latitude 5580 cdm80 la e091p rev 2.0
    The problem is that it is very slow and does not recognize the battery, and when I press the keyboard, it does not respond except after a long press and executes the command a lot
    What I did
    I tried another battery, the device works, but in the BIOS it gives a (not installed) message.
    I tried its battery on another device, it also works and its condition on the device is (good)
    I programmed the BIOS
    Is it possible to solve the problem with Clear ME?
    I attached the BIOS file
    And the device data
    And the battery status, knowing that the device works on it
    thanks
    try bios Clearme
    commented on 's reply
    Thread merged.
  • hamadasaad
    replied
    What I did
    And the device data
    thanks
  • LazNo01
    replied
    Dell latitude 5580 LA-E091P
    SN 11TZMH2
    ERROR: alert tpm device is not detected!
    any help me
    Test this
  • LazNo01
    replied
    Originally posted by LazNo01 View Post
    Hello people
    Dell latitude 5580 la-e091p rev 2.0 [ Service tag : 31LQ1N2 / express service code : 6627300302 ]
    power button blink when AC pluged but the laptop won't turn on .
    thank you .
    Update :
    After fighting with the laptop for almost 1 week , and while doing some reaserch i found that a non genuin AC adapter could trigger something caleld BD PROCHOT , which makes the cpu slow down ( mine was stuck at 600MHz ) . so after getting a orignal AC adapter , the laptop recover and become smother and the cpu frequency become normal .
  • doivaythoiem
    replied
    SN 11TZMH2
    any help me
  • LazNo01
    replied
    Originally posted by peste View Post
    post the original content of the bios chip, even if it is corrupted..
    you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
  • LazNo01
    replied
    Thank you for your response sir.
    i do have spi programmer and i know how to use it.
    i did include the original dump under the name OG_dump and the actual bios i'm using under the name current bios.
    Sorry, my mistake i didn't clarify that.
    Thank you
  • peste
    replied
    Hello people
    i did find here on the forum a donor bios for the exact model , so i did use that image and with the help of UEFItool i backup the Gbe / ME region from my corrupted bios and put it the donor using hexeditor
    the pc turned on fine but it was so slow , so i did re-install windows and all the drivers but still very slow , and there is a lot of drivers missing :
Name:	missing drivers.png
    so i'm thinking that i did something wrong because this is the first time i do a bios mod and i'm not very aware of the tools and methods to use for this kind of operation,
    so i need help to create a good working for this computer to get back normal again .
    thank you .
  • peste
    post merged..
  • LazNo01
    replied
    Hello people
    thank you .
  • testinglaptops
    replied
    Originally posted by pronto View Post
    Re: Dell Latitude 5580 (LA-E091P)
    Bios working
    THANKYOU, WORKED FOR ME. 100%
  • florenz
    replied
    Bios working
    THX MY BOSS
  • peste
    post merged..
  • ludo28
    replied
    Hi
    who can repair the dell latitude 5580 bios for me?
    tag:BRX1RN2
    THANKS
  • bykanovm
    replied
    Originally posted by SMDFlea View Post
    Thread merged. Your configuration based on the service tag:
    379-BCPQ : 7th Gen Intel Core i5-7300U Processor (Dual Core, 3MB Cache, 2.6GHz)
    340-BJXH : System Shipment, Latitude 5580 (TPM enabled)
    vPro enabled
    It should be using corporate LP firmware. What model is the CPU, has the motherboard been replaced
    Процессор 7th Gen Intel Core i5-7300U Материнская плата не менялась.
    replied
    Originally posted by bykanovm View Post
    Does not work. With the LP version the laptop does not turn on at all. With version H it turns on, consumption is no more than 0.25A, sometimes the fan spins, there is no picture.
    vPro enabled
  • bykanovm
    replied
    Originally posted by Blaze Tech View Post
    try
  • Blaze Tech
    replied
    Hello . I have a problem with my Dell latitude 5580 laptop, la-e091p REV 2.0 platform. When turned on, it writes the error “tpm could not be initialized” and requires pressing F1. In the BIOS itself, the TPM module version 1.2 is disabled, there is such a function. I upgraded the BIOS version to the latest 1.36. I downgraded the BIOS version to 1.33, but the standard method does not allow downgrading, although downgrade is allowed in the BIOS. I cleared the TPM module in the BIOS. I turned off all the power, nothing helps. Can someone help me with this problem? And in general, could this be a hardware problem? Here is my bios dump.
    ST:6WJS3G2
    try
  • bykanovm
    replied
    ST:6WJS3G2
