Dell Latitude 5580 (LA-E091P)
    • 21191
    Re: Dell Latitude 5580 (LA-E091P)
    Originally posted by danito
    Not working.
    The configuration of your laptop is with AMT disabled.
    The bios you tried has AMT enabled, look at some of the settings with FIT
    Compare with the bios at post #3
    The bios at post #3 should be ok,if you clean the ME firmware,as its initialised.
    • danito
      • Jun 2016
      • 1007
      #42
      Maybe I'll learn these once too.
      I will try #3 and come back.
      Thx
      • hanah
        • Mar 2018
        • 10
        • india
        #43
        Tpm error
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #44
          Originally posted by hanah
          Tpm error
          Read the rules before posting:
          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
          Become a Badcaps supporter
          Thanks to all supporters.
          • tomodachi
            • Apr 2012
            • 603
            • Turkey
            #45
            Can you help me with the problem I'm having?
            I didn't have a backup of the old bios, I found a bios that starts only because I have a problem with the network card that doesn't want to be installed.
            Can you help me?
            st: 9X35SN2
            thank you
            Exact same problem here, can someone give a hand please?
            is it possible to find virgin dump file from dell ?
            st : BDYZNH2
            btw my machine contains 1 SPI chip (16mb type)
            • lecong1986
              • Mar 2017
              • 19
              • vietnam
              #46
              Originally posted by hoaca388
              Re: clear me dell 5580 cdm80 la-e091p
              good, thank you
              • bykanovm
                • Aug 2022
                • 95
                • Украина
                #47
                Hello . I have a problem with my Dell latitude 5580 laptop, la-e091p REV 2.0 platform. When turned on, it writes the error “tpm could not be initialized” and requires pressing F1. In the BIOS itself, the TPM module version 1.2 is disabled, there is such a function. I upgraded the BIOS version to the latest 1.36. I downgraded the BIOS version to 1.33, but the standard method does not allow downgrading, although downgrade is allowed in the BIOS. I cleared the TPM module in the BIOS. I turned off all the power, nothing helps. Can someone help me with this problem? And in general, could this be a hardware problem? Here is my bios dump.
                ST:6WJS3G2​
                • Blaze Tech
                  Learner
                  • 205
                  • Ghana
                  #48
                  ST:6WJS3G2​
                  try
                  • bykanovm
                    • Aug 2022
                    • 95
                    • Украина
                    #49
                    Originally posted by Blaze Tech
                    try
                    Does not work. With the LP version the laptop does not turn on at all. With version H it turns on, consumption is no more than 0.25A, sometimes the fan spins, there is no picture.​
                      • 21191
                      Thread merged. Your configuration based on the service tag:
                      379-BCPQ : 7th Gen Intel Core i5-7300U Processor (Dual Core, 3MB Cache, 2.6GHz)
                      340-BJXH : System Shipment, Latitude 5580 (TPM enabled)
                      vPro enabled
                      It should be using corporate LP firmware. What model is the CPU, has the motherboard been replaced
                      • bykanovm
                        • Aug 2022
                        • 95
                        • Украина
                        #51
                        vPro enabled
                        Процессор 7th Gen Intel Core i5-7300U Материнская плата не менялась.
                        • ludo28
                          • Aug 2022
                          • 37
                          • france
                          #52
                          Hi
                          who can repair the dell latitude 5580 bios for me?
                          tag:BRX1RN2
                          THANKS​
                          • peste
                            peste commented
                            Editing a comment
                            post merged..
                        • florenz
                          • Apr 2018
                          • 43
                          • Cameroon
                          #53
                          Bios working
                          THX MY BOSS
                          • testinglaptops
                            • Oct 2022
                            • 78
                            • United Arab Emirates
                            #54
                            Bios working
                            THANKYOU, WORKED FOR ME. 100%
                            • LazNo01
                              • Sep 2023
                              • 21
                              • Algeria
                              #55
                              Hello people
                              Dell latitude 5580 la-e091p rev 2.0 [ Service tag : 31LQ1N2 / express service code : 6627300302 ]
                              power button blink when AC pluged but the laptop won't turn on .
                              i did find here on the forum a donor bios for the exact model , so i did use that image and with the help of UEFItool i backup the Gbe / ME region from my corrupted bios and put it the donor using hexeditor
                              the pc turned on fine but it was so slow , so i did re-install windows and all the drivers but still very slow , and there is a lot of drivers missing :
Name:	missing drivers.png
                              so i'm thinking that i did something wrong because this is the first time i do a bios mod and i'm not very aware of the tools and methods to use for this kind of operation,
                              so i need help to create a good working for this computer to get back normal again .
                              thank you .
                              • peste
                                peste commented
                                Editing a comment
                                post merged..
                            • peste
                              • 12967
                              • ROMANIA
                              #56
                              Originally posted by LazNo01
                              Hello people
                              thank you .
                              post the original content of the bios chip, even if it is corrupted..
                              you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                              • LazNo01
                                • Sep 2023
                                • 21
                                • Algeria
                                #57
                                Thank you for your response sir.
                                i do have spi programmer and i know how to use it.
                                i did include the original dump under the name OG_dump and the actual bios i'm using under the name current bios.
                                Sorry, my mistake i didn't clarify that.
                                Thank you
                                • LazNo01
                                  • Sep 2023
                                  • 21
                                  • Algeria
                                  #58
                                  • doivaythoiem
                                    • Jun 2024
                                    • 104
                                    • Việt Nam
                                    #59
                                    Dell latitude 5580 LA-E091P
                                    SN 11TZMH2
                                    ERROR: alert tpm device is not detected!
                                    any help me​
                                    • LazNo01
                                      • Sep 2023
                                      • 21
                                      • Algeria
                                      #60
                                      Hello people
                                      thank you .
                                      Update :
                                      After fighting with the laptop for almost 1 week , and while doing some reaserch i found that a non genuin AC adapter could trigger something caleld BD PROCHOT , which makes the cpu slow down ( mine was stuck at 600MHz ) . so after getting a orignal AC adapter , the laptop recover and become smother and the cpu frequency become normal .
                                        DELL Latitude 5580 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5580 boardview and 5580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5580...
                                        09-06-2024, 08:01 AM
