MacBook air Model A1466 EMC 2925 820-00165-A
  • mavaro
    ABCLAP_POLAND
    • May 2017
    • 33
    • Polska
    #101
    I would like to ask for help verifying the EFI/BIOS dump for a MacBook Air 13" 2015.
    MACBOOK not install recovery internet, no back entry etc.
    Model:
    - MacBook Air 13" Early 2015
    - Board number: 820-00165-A
    - Model ID: MBA71
    - SPI chip: 25Q64 (8 MB)
    Attached is the original BIOS dump read directly from the board.
    Could someone please check:
    - if the EFI region is intact,
    - if NVRAM/Recovery areas are valid,
    - if the dump is complete and not corrupted,
    - and whether this image is safe to rebuild/clean?
    Any help or confirmation would be greatly appreciated.
    Thank you!
  • Nebukadnerzar_V
    • Oct 2017
    • 27
    • Deutschland
    #102
    Hi! I have a MacBook Air 2015, that will not POST.
    It swiches on, fan comes on and at normal speed (SMC --> OK), but it will not POST or boot.
    I suspect a BIOS/EFI issue.
    Please find the dump attached. If someone could provide me with a clean BIN or clean my dump, I would be very happy.
    A1466 EMC2925
    S/N: C02RGGPHG940
    • peste
      • 15567
      • ROMANIA
      #103
      A1466 EMC2925
      S/N: C02RGGPHG940
      try...
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
      It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • DZ-Developer
        • Nov 2022
        • 32
        • Algeria
        #104
        can help me to clean my bios password?
        Thanks and Advance...
        Model MacBook AIR
        Model Number A1466 EMC2925
        Serial C02S43BPH3QF
        Board ID 820-00165-A
        all donations are welcome,
        see the donate button below, at the bottom of the page, or
        >>>>> click on this link to donate via PayPal. <<<<<
        Doctrina est fructus dulcis, radicis amarae
        • shiyab
          • Sep 2023
          • 3452
          • india
          #105
          Model MacBook AIR
          Serial C02S43BPH3QF
          hi try
          • yura8
            Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
            by yura8
            Hi there! I have not so usual situation...
            I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
            My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
            P.S. If you have else any ideas about repair, or you had a similar...
            12-20-2024, 02:31 PM
          • Boardview and Schematic Bot
            Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
            Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
            Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
            06-20-2026, 10:11 AM
          • sofles
            Macbook a1707 2017 model 820-00928 GPU issue
            by sofles
            Hello there
            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
            11-21-2024, 05:25 AM
          • psdavid65
            Macbook Air A1466 820-3437-B Booting Problem
            by psdavid65
            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
            06-20-2024, 12:27 AM
          • Rubedizzle
            MacBook Air A1466 820-00165-A - No POST/Fan Spin, has charging light
            by Rubedizzle
            Hey folks, came across a 2017 13" MacBook Air A1466 820-00165-A system that does not power on. When charger is plugged in, it will show a green then orange light, and eventually green light as the battery gets charged. Just no fan spin or response when pressing power button.
            Tried SMC Reset and NVRAM/PRAM reset etc, nothing.
            Took it apart, and no signs of corrosion anywhere, trackpad cable/keyboard cable all look good. Flipped board over, and U8040 is cracked, see attached. This appears to be a load switch for the audio system. I've ordered a replacement component...
            04-20-2026, 03:30 PM
