Hp dv6700 need bios
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Hp dv6700 need bios
    Does anyone have a working bios for this model HP DV6700 please. laptop stock on hp logo.please help share a working bios please.
    Board idA0AT1MB8H0 REV:H
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: Hp dv6700 need bios
    need help please
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      anyone please help. I have attached my original bios dump which stack at hp logo can someone fix this dump please
        • 20643
        Try the one at post #8 https://www.badcaps.net/forum/showthread.php?t=51369
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          @smdflea not working bios from post8 turns on no display and goes off.can someone fix my original dump please
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            need help please fix my original dump.original working but stack on hp logo
              • 20643
              Try this one
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                still not working turns on but no display i try original working but stack at hp logo can anyone fix my original dump please
                  • 20643
                  Try these 2 bios,these are the right ones this time.
                  Quanta 30CF 85.24 DV6710ea ,AMD cpu,Nvidia GPU .
                  • Romulo
                    • Nov 2016
                    • 484
                    • Philippines
                    I flashed the bios with the first one its working display comes but still the same issue stack at hp logo, i can enter bios setup but once i save it and restart it stack and not booting up.anyone please help
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Nvidea gpu issue????
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        does this nvidia gpu is the problem?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          I have doubts on nvidea gpu as this dv6000 series is known or rather famous for nvidea gpu failure.
                          • Romulo
                            • Nov 2016
                            • 484
                            • Philippines
                            i doubt also because original bios has display but stack on hp logo maybe someone can share a working bios for this model please
                            • mielta
                              • Apr 2015
                              • 368
                              Hi
                              This is an Orginal Bios from this Board
                              I have it desoldered and make an bin for you
                              • t17101990
                                • Jun 2020
                                • India
                                is your problem solved yes no
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • DynaxSC
                                  by DynaxSC
                                  11-17-2023, 10:56 AM
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • AkaBukai
                                  Is it okay to flash stock bios onto the motherboard's BIOS?
                                  by AkaBukai
                                  Hi there,
                                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                  The little LED on the power button is flashing slowly and nothing happen.
                                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                  So I decided to flash the BIOS using a cheap programmer.
                                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                  I also...
                                  12-19-2024, 12:15 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
