hp 8760w wont turn on blinking led after replacing bios
  • Diesalweasel
    • May 2016
    • 49
    • United Kingdom
    hi need some help please originally the laptop turned on .but had bios password . so i removed the chip as i couldn't read it no other way . after program it was all successful put chip back on board and all i get as soon as i plug battery in is blinking white and orange led .even if i connect charger and remove battery or both. so i took chip back off and flashed it with original bios dump but still the same issue both times the chip was successful in programing there is no signs of life only the blinking led
    where do i need to start checking with multimeter ?
    best regards james
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: hp 8760w wont turn on blinking led after replacing bios
    First find a new clean dump, if it didn't work then change the bios chip.
      • 21035
      Heres another bios to try,its based on a 3MB HP update,another bios in the thread where i removed your original password,your DMI added,and clean ME added .
      • Diesalweasel
        • May 2016
        • 49
        • United Kingdom
        hi almost there . laptop now powers on for a split second then goes off fan kicks in . there is no display on the screen it just pure black.it now charges battery the blinking light has now gone. any ideas fink the bios file probably needs a fine tuning
        best regards
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          try this dump too.
          • tibd
            • Oct 2014
            • 189
            • Sweden
            This one might help
            • midihead7
              • Dec 2019
              • 14
              I recently had a virus that corrupted my BIOS on an HP EliteBook 8760w laptop. I bought a ch341a programmer and flashed the BIOS numerous times. I did not have a clean dump from this machine so I have tried pretty much every dump shared in this forum for this laptop. Some dumps don't allow the laptop to power on at all (charging light just blinks). The last two shared in this thread have "occasionally" allowed me to get into the BIOS setup. Once in the BIOS setup, the laptop soon shuts off on its own and tries to reboot even with no hard drive installed at all. When trying to boot from a known clean drive, it gets part way through the boot process and abruptly shuts off before Windows can fully boot. The weird thing is that after a partially successful attempt to access the BIOS setup is made (followed by the abrupt shut off), the next time I try to power on the laptop, it just power cycles the fan and lights but does not try to boot at all which causes me to have to keep reflashing the chip.
              I can't imagine that the BIOS virus/malware corruption has survived the multiple erasing and flashing attempts so I'm thinking that the BIOS dumps I've tried aren't 100% compatible with my motherboard. Does anyone have idea other ideas to help me get the BIOS to be stable on this machine? I'm at my wit's end. Many thanks to you.
              • midihead7
                • Dec 2019
                • 14
                I should add that when I am occasionally able to try to boot into Windows 10 (which fails due to the sudden shutoff), I see a message that says "ME state is in recovery mode" in case this is important to know.
                • digitalpc
                  • Jun 2016
                  • 305
                  • .DLL
                  can u make a pic around chip
                  i think something around bios chip is touching, can be chip pins check again
                  • midihead7
                    • Dec 2019
                    • 14
                    It doesn't appear to me that anything is touching the chip but I have attached a picture.
                      • 21035
                      The small cap above the bios chip looks like its dislodged.Could be track damage too .
                      • midihead7
                        • Dec 2019
                        • 14
                        Attached is a picture of the BIOS chip on a different laptop (exact same model). That cap looks the same on both motherboards. The BIOS on both laptops were affected by the same virus.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          If the BIOS corruption was because of malware, then it's highly likely that the BIOS gets re-contaminated when the drive is read!
                          Albeit the symptoms sound more like the RAM not having proper contact.
                          The fan going full blast, may mean poor RAM contact.
                          A shut down, may be bogus high temp readings, unless the heatsink is bad or dirty.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • mr.Data
                            • Sep 2018
                            • 74
                            • Netherlands
                            best regards james
                            I have the same problem with one of the 8760w. Tested all the BIOS dumps in this thread but nothing worked.
                            Then I tried a chip from a working 8760w but still got the same problem. For those that are looking for a working BIOS dump... This one comes from a working 8760w
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • thxd43
                              Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                              by thxd43
                              Hello, first of all, excuse me, I am using the translator, English is not my native language.
                              I have a Lenovo ideapad 330S - 14IKB laptop.
                              The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                              02-23-2023, 08:37 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
