What bios programmer to get
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Which bios programmer to get that works for all laptops.
    Can you advise
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: What bios programmer to get
    I use CH341A programmer. But for 1.8v chips you will need to get an adapter.
    • Stevie2001
      • Apr 2018
      • 183
      • irland
      Is tl866cs any good
      • akande
        • Dec 2017
        • 278
        • Nigeria
        Originally posted by Stevie2001
        Is tl866cs any good
        very good bro
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You can consider Rt809F which is very cheap and efficient as well. For 1.8v chip you need to use adapter. It can program Ene kbc also.
          • KvnTM
            • May 2018
            • 434
            I actually use an Arduino. Slower but it works
            • Stevie2001
              • Apr 2018
              • 183
              • irland
              Thanks guys
              • Siddig
                • Jun 2017
                • 264
                • Sudan
                tl866cs its best for bios
                Rt809F it's good for bios and ene and it Io chip
                Svod 3 it's good for all kbc Io programing
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  The tl866cs wil that work on most modern laptop bios
                  • snsent
                    • Nov 2010
                    • 103
                    • Malaysia
                    Im using EZP2013... Can use with offset bios file...
                    • tomodachi
                      • Apr 2012
                      • 603
                      • Turkey
                      I own both TL866CS and RT809F, RT809F will be your best bet,
                      Tl866CS is good but very slow at programming.
                      RT809F will be there for programming most KBC chips such as ITE8586E and KB9012~22 series but you will need an adapter which is not very expensive. And another adapter for 1.8V chips.
                      • Stevie2001
                        • Apr 2018
                        • 183
                        • irland
                        Aslong the tl886cs does the job its ok.
                        Can it programme aio ic also
                        • tomodachi
                          • Apr 2012
                          • 603
                          • Turkey
                          No, it only flashes SPI, eprom or pic
                          • Stevie2001
                            • Apr 2018
                            • 183
                            • irland
                            Ok thank's just to be clear.
                            To flash the ITE ic's and other similar sized one's what's the board name that does it
                              • 21124
                              RT809H ,you`ll need kbc adapters, its also a bios programmer.
                              Vertyanov programmer , the original kbc programmer. Only for kbc, and edid
                              SVOD3 KBC,SPI, NAND and eMMC support coming.
                              • playit
                                • Feb 2020
                                • 182
                                • india
                                hi.. i have dg41cn motherboard ,bios chip is 25Q16BVAIG ,can i flash it with eeprom CH341A? i am thinking of buying it ,if it would help.. thanks
                                • zak1n
                                  • Mar 2019
                                  • Czech
                                  Hello guys, I found this website about programming kb9012 with ch341A programmer. Somebody tried or is it even possible? I need flash kb only once in my life so it is useless to spend money for rt809F
                                  http://dangerousprototypes.com/docs/...ith_Bus_Pirate
                                  • kiraro
                                    • Jan 2016
                                    • 177
                                    • North NY
                                    yes i successfully flash kb9012 with ch341A
                                    • STKR123
                                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                      by STKR123
                                      Greetings badcaps community,
                                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                      I learned that desoldering...
                                      10-29-2024, 06:03 AM
                                    • hotcrossedbuns999
                                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                      by hotcrossedbuns999
                                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                      3. I could only locate two chips that look like bios chips. Could someone verify this
                                      01-03-2025, 12:32 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • zlr8r
                                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                      by zlr8r
                                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                      cheers
                                      Dell Inspiron 17 (7786) Laptop
                                      Service Tag: 5J0NHT2
                                      Bios: 1.9.0
                                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                      Attached;
                                      1. My saved bios using a programmer
                                      2. Dells Bios updater .exe (v1.16)
                                      3. Dells Bios recovery file
                                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                      5. Image of ME...
                                      12-18-2023, 03:08 PM
                                      by Vesko356
                                      08-11-2023, 03:27 AM
