HP DMI Tool NBDmiFit
  • Biosuser1
    replied
    Re: HP DMI Tool NBDmiFit
    Tanks
    replied
    Originally posted by Dragunbayne
    Does anyone have a newer NBDmiFit? I have a 450 G5 that I got a replacement board from HP for and I don't think any in this thread are new enough.
    Use HP BCU, bios config utility.
    replied
    [QUOTE=Skunch;976137]okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
    My own bit of research tells me that the feature byte is a long, case sensitive string of letters and numbers and it looks like this:
    2U3E3X47676J6S6b727B7H7M7R7S7W7m7saBb3da.3Y
    (this feature byte is for a ProOne 600 G2)
    As for build ID...
    I can't commit the board until I enter these last two fields! Does anyone know how I can find that info?
    I have a 9470m i7 motherboard with HD+ graphics (1600x900)
    Go to this site and enter your serial and country.With any luck the feature byte will be there.
    https://partsurfer.hp.com/Search.aspx
  • Dragunbayne
    replied
  • Skunch
    replied
    As for build ID...
    also, classic bart mooning smilie? heck yes!
  • alas3376
    replied
    Originally posted by Miquell210
    Job done.
    WnDmiFit 2.07 working properly - all data changed successfuly.
    All done by creating pendrive in Rufus and used DOS version.
    Source I faund here:
    https://aiotutorials.wordpress.com/tag/wndmifit/
    Thanks for help all.
    thank you very much for sharing
  • Skunch
    replied
    Hello, I have an elitebook 9470m. I purchased a new motherboard and installed it. I have the error with the alert: "machine not in committed state"
    I'm not sure how to go about fixing this, as I have read online many people have this problem with new motherboards. Windows boots and functions normally. Does anyone know if I can fix this with software? A new part is nice, but am I better off returning the motherboard for a used one?
  • imranromi
    replied
    Already tried:
    - HP BIOS Configuration Utility (BCU) - unsuccessful
    -- wndmifit is not common to download - most of download links are going to 404 error or contain fake files - tried so far v 2.09 then v 1.1d to 1.14D
    I am keep looking
    Now you done is good i done always via bios dump modified this type error.
  • Miquell210
    replied
    Originally posted by SMDFlea
    Use HP bios config utility BCU ,and/or wndmifit from windows or nbdmifit from UEFI flash drive . Use version 2.10 or above.
    Job done.
    replied
    wndmifit is included inside the nbdmifit folder. Page #1 post #1 of this thread has different nbdmifit versions,try 2.10 in UEFI.The site is working ok, no 404 pages for me. You can post your bios in the "Bios Requests" sub forum if you want someone to try repair it for you - https://www.badcaps.net/forum/forumdisplay.php?f=40
  • Miquell210
    replied
    Originally posted by imranromi
    Post here bios dump if will fix.
    Already tried:
    I am keep looking
  • Miquell210
    replied
    Already tried:
    I am keep looking
  • imranromi
    replied
    Hello all.
    This is my first post as new user so hello all.
    Got similar problen with my laptop HP-15-r101na.
    After replacing motherboard receiving three error which I expected to easly fix.
    Well - not really.
    Can find proper tool to do so.
    1. System Board (00A) - Product Name
    2. System Board (00A) - Product Serial Number
    3. System Board (00A) - Product Number
    The only one think able to do was to update BIOS to version F.45
    Then I`ve tried to use different version of NbDmiFit with error platform not supported
    According to HP Serial Number Repository (Product Configuration Tracker) laptop was manufactured in 2014 so I`ve used tools supporting in theory this model - but platform not supported appear in DOS, Windows, WindowsPE
    Can you recommend proper tool or any idea what I am doing wrong, please.
    replied
    Hello all.
    Well - not really.
  • Miquell210
    replied
    Hello all.
    Well - not really.
  • sojibbhi
    replied
    Why i cant download the file...please help me
  • martin lippert
    replied
    Originally posted by Murtaza527
    bro i have 840 g3 for unlock but i tried put smc.bin file into usb fat32 but cant boot with usb or not showing sms command handled successfully
    I have found out that you will need a specific SMC.bin file, which is composed be HP and requires serial numer as well as UUID.
    If you just use the standard FSMC.bin file an rename it, you will end up with error message SMC comand failure.
    Does anybody know, how to get this calculation done?
    Or get in touch by email with HP?
    KRs, Martin
  • lapfix
    replied
    pleasr , how to copy/paste the DMI info from bios to other under windows , not with boot usb.
    or the only way is NBDmiFit tool !!
    replied
    Originally posted by Alien71
    Hi Techman1025,
    Are you able to generate a specific smc.bin file for unlocking a bios password protected for an HP Probook 6460B please ? (Sorry for my bad english).
    Thank you for your answer.
    Post your bios in the "Bios Requests" sub-forum and one of the members will remove the pass for you.
  • Alien71
    replied
    Hi Techman1025,
  • rex98
    HP DMI Tool
    by rex98
    HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
    DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
    The DMI Tool given here are for personal use only.
    DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
    You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
    from it, and that you please credit the author...
    07-02-2025, 05:51 AM
  • tsavpyn
    Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
    by tsavpyn
    Dear all,
    I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
    Now I have a problem that I am unable to dump my BIOS into bin file.
    My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
    I searched for FPT but there is no Linux version and none of them work.
    I hereby request a copy of Intel Flash Programming Tool for Linux x64.
    I would really appreciate it if anyone...
    05-28-2024, 11:18 PM
  • salim5566
    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
    by salim5566
    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
    06-26-2025, 03:25 PM
  • shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool
    by shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool.
    Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
    anyone having it, please share
    Thank you
    07-08-2025, 06:42 AM
  • tony359
    Best tool to place electrolytic SMD caps on a board
    by tony359
    HI all,
    I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
    When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
    The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
    01-28-2024, 06:23 AM
