Bios need Asus N551ZU
  • snsent
    • Nov 2010
    • 103
    • Malaysia
    Bios need Asus N551ZU Rev 2.0
    I attach together my dump here.
    Thanks In Advance
  • cacla
    • Apr 2015
    • 442
    Re: Bios need Asus N551ZU
    Try this one
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • oragano
      ASUS ex-b250-V7 motherboard bios corrupted - by me
      by oragano
      hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
      So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
      i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
      10-17-2024, 02:53 AM
    • chudofermer
      Asus Ally rc71l bios
      by chudofermer
      Hello!
      Received Asus Ally rc71l with the wrong bios.
      Have the original package and all serial numbers.
      Can anyone help me understand what is wrong?
      Condition:
      Received with an original box with all serial numbers
      Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
      Got the flash dump, nothing found on DMI section
      No Windows key, just key ID on the box
      What is done:
      1. Flash the latest bios version with serial numbers...
      03-05-2025, 05:42 AM
