ASUS ROG G750JY MB G750JZ REV 2.0 IT8585 dump file, tested
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I know these are really hard to come by so here you go. Taken from a WORKING machine after repair, this board had a fairly unusual fault, but one that was easily repaired.
    Flash has been read with SVOD Programmer and has been verified. It *may* work with other ASUS ROG G750 versions as the KBC IT8585 is the same.
    A working TV? How boring!
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • Mephysis
    DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
    by Mephysis
    Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
    I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
    03-27-2025, 02:34 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
  • re-atari
    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
    by re-atari
    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
    02-03-2025, 06:49 PM
